[Geomoose-users] LatLon coordinate system
t faustino geomatrix3d at gmail.com
Tue Jul 7 13:46:53 EDT 2009
I'm trying to utilize mapserver's built in latlon coordinate system.
My test layer is WGS84 format (it is the only layer)
I received an error in the Geomoose.js stating coordinate system not
defined as defined by this line in the Geomoose.js:
"var CoordinateSystemFiles=new
Array();CoordinateSystemFiles['UTM']='projections/utm.js';CoordinateSystemFiles['MNCOUNTY']='projections/mncounty.js';function
loadCoordinateSystem(){var CoordSys=new
String(MAP_COORDINATE_SYSTEM).split('-');"
......etc etc.
Makes sense of course. My question is how do I redefine the javascript
to use WGS84? Do I preclude the above statement or directly redefine
it as LatLon.....if someone would be kind of enough to kick my butt in
the right direction. Thanks!
@ Brian Fischer: thanks for your help thus far - I didn't want to bug
you with another email to email correspondence.
"If one advances confidently in the direction of his dreams, and
endeavors to live the life which he has imagined, he will meet with a
success unexpected in common hours."  ~Thoreau
More information about the Geomoose-users mailing list
