[Geomoose-users] Highlight projection issue
Len Kne lkne at houstoneng.com
Thu Jun 17 17:25:33 EDT 2010
So it looks like there is some work to be done with GeoMOOSE services to fully support querying layers in projections different than GeoMOOSE...  Since you are using PostGIS, you could do the transformation there with st_transform().  The re-projection can also happen on the service-side of the service or on the client-side with a GeoMOOSE user extension. This should work:
TransformAndZoomExtension = new OpenLayers.Class(GeoMOOSE.UX.Extension, {
        srcPrj: new OpenLayers.Projection('EPSG:26915'),
        load: function() {
        zoom: function(minx,miny,maxx,maxy) {
                var bounds = new OpenLayers.Bounds(minx,miny,maxx,maxy).transform(this.srcPrj,Map.projection);
                Map.zoomToExtent(bounds);
        CLASS_NAME: "TransformAndZoomExtension"
GeoMOOSE.UX.register('TransformAndZoomExtension');
transformAndZoom = new TransformAndZoomExtension();
Look at http://www.geomoose.org/docs/user_extensions.html for details on adding a user extension to GeoMOOSE.
Then in your template, you would point to transformAndZoom.zoom([shpminx],[shpminy],[shpmaxx],[shpmaxy]);
Len
-----Original Message-----
From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
Sent: Thursday, June 17, 2010 2:33 PM
To: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Highlight projection issue
Followup to my own message.
I have confirmed that the link returned by the javascript snippet below contains the correct extent IF interpreted as the original EPSG:26915 projection.
In other words somewhere along the way the bounds are not reprojected.
If I use a single water well in my PostGIS (that uses EPSG:26915) as example:
Stored coordinates are 748178.83, 333429.45 in NAD83 UTM15N.
Mapserver projects those to EPSG:900913 and obtains -10066017.27, 3517260.50 according to my Geomoose interface, which uses 900913. This is the correct location.
If I use my Geomoose interface and check the location in Algeria, it is indeed in agreement with the UTM numbers above.
To reiterate, all locations plot in the correct location, the highlight is now in the correct location, but the query-generated link appears to use the unprojected EPSG:26915 coordinates, taking me to Algeria.
What can I do?
Thanks!
Johan.
> Sent: Thursday, June 17, 2010 11:17 AM
> Subject: [Geomoose-users] Highlight projection issue
> All:
> Focusing on the itemquery/highlight.map projection issue now. I
> thought I had it covered, but the plot has thickened.
> Making the changes described below indeed fixed the highlight problem,
> but there is still an underlying issue.
> If I click on the link generated by the
> javascript:GeoMOOSE.changeLayerUrl('highlight',...
> GeoMOOSE.zoomToExtent(662056.373600,3344506.451400,662056.373600,33445
> 06.4
> 51400)
> function in the template file it zooms to the same spot in Algeria
> that the highlight was previously placed.
> There is clearly something sinister going on with the source of that
> extent.
> Where can I look / what info can I provide to help troubleshoot this?
> Or am I simply overlooking something embarrassingly simple?
> Thanks!
> Johan.
> > Sent: Thursday, June 17, 2010 8:03 AM
> > To: Len Kne; geomoose-users at lists.sourceforge.net
> > Subject: Re: [Geomoose-users] query.php configuration confusion
> > Ok, I found a solution to the highlight issue.
> > Adding the 900913 projection block to the MAP section in
> > highlight.map
> did
> > not by itself change anything. However, if I also added the
> > projection that the data is stored as in the LAYER definition in the
> > highlight.map files it worked.
> > To summarize, to make the query and select highlighting work, in my
> case,
> > when the data is stored in a different projection than what is used
> > in
> the
> > final output, the highlight.map files must look similar to this:
> > MAP
> > PROJECTION
> >     "init=epsg:900913"
> > END
> > TRANSPARENT true
> > SYMBOL
> >     NAME 'circle'
> >     TYPE ellipse
> >     POINTS
> >             1 1
> >     END
> >     FILLED true
> > END
> > LAYER
> >     PROJECTION
> >             "init=epsg:26915"
> >     END
> >     NAME 'points'
> >     TYPE POINT
> >     STATUS DEFAULT
> >     CLASS
> >             SYMBOL 'circle'
> >             COLOR 0 255 255
> >             SIZE 16
> >     END
> > END
> > > From: Len Kne [mailto:lkne at houstoneng.com]
> > > Sent: Wednesday, June 16, 2010 3:47 PM
> > > To: Johan Forsman; geomoose-users at lists.sourceforge.net
> > > Subject: RE: query.php configuration confusion
> > > Your parameters look right.  How about this -  queryitem, query
> > > and
> > select
> > > create a temp shape file with the results and then use a built in
> > > map
> > file
> > > to show the results.  Look for highlight.map in
> > > htdocs/php/itemquery and/or htdocs/php/select.  In the MAP object
> > > of the file, add the
> 900913
> > > projection information.  This should re-project the highlight
> > > results before returning them to GeoMOOSE.
> > > Len
> > > Sent: Wednesday, June 16, 2010 3:37 PM
> > > Hi Len, thanks for the response.
> > > On Issue 1  suspected that was it. I will attempt to craft an
> > > expanded section for each layer I wish to query.
> > > On Issue 2:
> > > Settings.ini contains
> > >   projection=EPSG:900913
> > > Mapbook contains
> > >   <param name="projection">EPSG:900913</param>
> > > Mapfiles contain
> > >   PROJECTION
> > >           "init=epsg:900913"
> > >   END
> > > at the top, and
> > >   PROJECTION
> > >           "init=epsg:26915"
> > >   END
> > > for each layer.
> > > Did I miss something?
> > > Thanks!
> > > /Johan.
> > > > Sent: Wednesday, June 16, 2010 3:22 PM
> > > > Hi Johan
> > > > Issue 2 - check conf/settings.ini to see what the projection is
> > > > set
> > to.
> > > > Server-based services use this value for the projection, while
> client-
> > > > based services use the mapbook.
> > > > For issue 1, I think you are going to need "fieldnameX" for each
> layer
> > > > you are querying.  As your service is now configured, I would
> > > > expect it to only query Layer0 using fieldname0 and value0.  I
> > > > do not
> believe
> > > > you will be able to query across multiple layers with one value
> > > > without some custom coding of query.php.
> > > > Len
> > > > Sent: Wednesday, June 16, 2010 2:08 PM
> > > > Subject: [Geomoose-users] query.php configuration confusion
> > > > All:
> > > > Two issues to seek advice on this afternoon.
> > > > Platform is GM2.2, using webmaps as base with EPSG:900913 in the
> > > > mapbook and settings.ini files. Source data is in EPSG:26915,
> > > > being projected on- the-fly by MapServer to EPSG:900913. All
> > > > layers I have render very nicely in all the right spots.
> > > > Issue 1:
> > > > I would like to use the new query.php function to search several
> > > > tables in my PostGIS from one dialog. I have looked at the
> > > > examples
> in
> > > > the documentation but it appears I am not fully comprehending
> > > > the
> > > syntax.
> > > > I have 5 layers I wish to search, each has its own table in PostGIS.
> > > > 6 of the layers/tables have 2 identical fieldnames I wish to be
> > > > able to search on, "pwsid" and "sysname".
> > > > The remaining table has two fields I wish to be able to search
> > > > on, "regowner" and "newid" (ignore layer4 for now).
> > > > I used the "query.php" block from the demo mapbook and
> added/replaced
> > > > my own layers.
> > > > When I test the query layer0 and layer1 are turned on in the
> > > > map,
> but
> > > > results are only returned for layer0.
> > > > I have a <input type...layer? for each layer.
> > > > I have a <input type...template? for each layer entry, but they
> > > > all use value="itemquery" since each layer definition in the
> > > > referenced mapfiles have unique templates defined there.
> > > > I am suspecting the problem lies somewhere with the "fieldname0"
> > > > and "value0" parameters? In fieldname0 I have included all 4 of
> > > > the fields, from 5 different tables, I wish to be able to
> > > > specify the
> > search
> > > from.
> > > > At the bottom of this message I have placed the query.php block
> > > > as
> it
> > > > looks currently. Please ignore the square footage bit; it's
> remaining
> > > > from the demo, and I don't have an immediate need for the
> > > > boolean
> > > functions.
> > > > I have been unable to stitch together a series of input types
> > > > that covers the bases. Does someone on the list have a query
> > > > block to
> share
> > > > that does this that I may model mine after?
> > > > Issue 2:
> > > > All the layers plot where they should, but the highlights from
> > > > the query results plot in Algeria. To emphasise, ONLY the
> > > > highlights
> plot
> > > > in the wrong place.  Clearly a projection error, but where? This
> also
> > > > happens with the old itemquery.php since I switched from using
> > > > EPSG:26915 in my mapbook to EPSG:900913.
> > > > Thanks for taking the time!
> > > > And I do apologize for the rudimentary XML skills that are
> apparently
> > > > absent in my mapbook.
> > > > /Johan.
> > > >         <service name="search_facilities">
> > > >                 <url>php/query.php</url>
> > > >                 <step type="input">
> > > >                         <input type="hidden" name="highlight"
> value="true"/>
> > > >                         <input type="hidden" name="mode" value="search"/>
> > > >                         <input type="hidden" name="layer0"
> > > > value="wells/sdwis_wells"/>
> > > >                         <input type="hidden" name="layer1"
> > > > value="surfacewater/intakes"/>
> > > >                         <input type="hidden" name="layer2"
> > > > value="surfacewater/treatmentplants"/>
> > > >                         <input type="hidden" name="layer3"
> value="storage/all"/>
> > > >                         <input type="hidden" name="layer4"
> > > > value="wells/swap_wells"/>
> > > >                         <input type="hidden" name="layer5"
> > > > value="wells/ldotd_all"/>
> > > >                         <input type="hidden" name="template0"
> > > > value="itemquery"/>
> > > >                         <input type="hidden" name="template1"
> > > > value="itemquery"/>
> > > >                         <input type="hidden" name="template2"
> > > > value="itemquery"/>
> > > >                         <input type="hidden" name="template3"
> > > > value="itemquery"/>
> > > >                         <input type="hidden" name="template4"
> > > > value="itemquery"/>
> > > >                         <input type="hidden" name="template5"
> > > > value="itemquery"/>
> > > >                         <input type="select" name="fieldname0"
> title="Search
> > > By:">
> > > >                                 <option value="sysname">System Name</option>
> > > >                                 <option value="pwsid">PWSID</option>
> > > >                                 <option value="regowner">Registered
> owner</option>
> > > >                                 <option value="newid">Well id
> number</option>
> > > >                         </input>
> > > >                         <input type="select" name="comparitor0"
> title="That: ">
> > > >                                 <option value="like-icase">Contains</option>
> > > >                                 <option value="right-like-icase">Begins
> > > With</option>
> > > >                                 <option value="eq-str">Matches
> Exactly</option>
> > > >                         </input>
> > > >                         <input type="user" name="value0" title=""/>
> > > >                         <input type="hidden" name="fieldname1"
> > > > value="FIN_SQ_FT"/>
> > > >                         <input type="select" name="operator1">
> > > >                                 <option value="or">OR</option>
> > > >                                 <option value="and">AND</option>
> > > >                         </input>
> > > >                         <input type="select" name="comparitor1"
> title="Having
> > > Fin. Sq. Ft.
> > > >                                 <option value="gt">Greater Than</option>
> > > >                                 <option value="eq">Equal To</option>
> > > >                                 <option value="lt">Less Than</option>
> > > >                         </input>
> > > >                         <input type="user" name="value1" title=""/>
> > > >                 </step>
> > > >         </service>
> > > > ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad
> > > > Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.
> > > > See the prize list and enter to win:
> > > > http://p.sf.net/sfu/thinkgeek-promo
> > > > _______________________________________________
> > > > Geomoose-users mailing list
> > > > Geomoose-users at lists.sourceforge.net
> > > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
