[Geomoose-users] Search Results zoom to, highlight etc not functioning
Len Kne lkne at houstoneng.com
Fri Sep 24 09:50:58 EDT 2010
Hi Sean
I suspect the difference in the projection between the data and the map may be the issue.  If you look at the response in Firebug, I'm would expect the coordinates are going to be in 2913, which are not going to match up anywhere on the map.  For example with the zoom-to service, if the coordinates are outside the max extent of the map, it will zoom to the center point of the map.
A quick check would be to re-project the taxlots to 900913 and see if the services work properly.
Len
From: Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent: Friday, September 24, 2010 12:00 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Search Results zoom to, highlight etc not functioning
The input "ID" you are referring to would be where it says "<input type="hidden" name="id"
value="ACCOUNT_ID" />" for a service?  The "ACCOUNT_ID" in that line is the attribute name in my taxlot shapefile.  As far as the projection question my data is in epsg:2913 but my map is in epsg:900913 to utilize the google layers.
Thanks,
Sean
Disclaimer:  This is a customized version of GeoMOOSE and the answer does not generally apply to the current GeoMOOSE version (2.2).  One thing to check is input "ID" for those services - this needs to be the key field for that data source.  Is the data in a different projection than GeoMOOSE?
Len
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100924/a05538af/attachment.html
More information about the Geomoose-users mailing list
