[Geomoose-users] POLL: Geomoose 2.2 or 2.4 on the Live DVD, which is more stable?
Brent Fraser bfraser at geoanalytic.com
Thu Jun 16 15:06:27 EDT 2011
Bob,
   I'm a little off-topic, but I think we need to formalize our testing
when we do a release (unfortunately I didn't have time to spend on v2.4
rc1).
   I just installed GeoMOOSE v2.4 Web Mercator Demo and MS4W on Windows
XP with IE 8, and it failed to load the page.  I had to install the
Microsoft Visual C++ 2008 SP1 Redistributable Package to get PHP to
work, but I think that's MS4W's problem.
   For GeoMOOSE, I had to remove the trailing comma on line 2216 of
compiled.js to get:
                     resolutions: CONFIGURATION.scales
And I had to uncomment the mapping library script includes in
geomoose.html.
Best Regards,
Brent Fraser
On 6/15/2011 12:05 PM, Bob Basques wrote:
> Dan,
> Well, the examples I was referring to, were those on the GeoMoose
> site.  Which I've had get fouled up with the navigation tools.
>  Sometimes the interface gets lost if you jump back and forth from the
> on map controls to the top tool bar controls in the mercator demo for
> example.
> The parcel ID function in the county demo is outputting some MapServer
> errors.
> I was planning on just copying these into the Live DVD originally, but
> they look like they need fixing, at least in the case of the Parcel ID
> stuff.
> So, should I copy them and configure for 2.4 or fix the 2.2 version?
> bobb
> >>> Dan Little <danlittle at yahoo.com> wrote:
> There is absolutely nothing in 2.2 that should work that doesn't in
> 2.4.  The code is not that different.  Fix your configuration.
>     *From:* Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>     *To:* "geomoose-users at lists.sourceforge.net"
>     <geomoose-users at lists.sourceforge.net>
>     *Sent:* Wednesday, June 15, 2011 11:30 AM
>     *Subject:* Re: [Geomoose-users] POLL: Geomoose 2.2 or 2.4 on the
>     Dan,
>     That's the problem.  I had to build a case to include some local
>     demos in the LIVE DVD installer ,but not everything seems to work
>     in the 2.2 stuff, so to fix, it seems better to address the same
>     capabilities in the 2.4 version instead of repairing the 2.2 demos.
>     bobb
>     Ugh... Yeah, GM2.4 has a ton of fixes that are reasonably
>     important.  Especially when you take it away from the demo
>     configuration.
>         *To:* geomoose-users at lists.sourceforge.net
>         *Sent:* Wednesday, June 15, 2011 9:24 AM
>         *Subject:* [Geomoose-users] POLL: Geomoose 2.2 or 2.4 on the
>         All,
>         in your estimation (of those that have used GM2.4, would you
>         think that 2.4 is more or as stable as GM2.2?
>         It has been suggested that using GM2.2 for the LiveDVD may be
>         better than going with a newer version.
>         Any thoughts?
>         bobb
>         EditLive Enterprise is the world's most technically advanced
>         content
>         authoring tool. Experience the power of Track Changes, Inline
>         Image
>         Editing and ensure content is compliant with Accessibility
>         Checking.
>         http://p.sf.net/sfu/ephox-dev2dev
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.sourceforge.net
>         <mailto:Geomoose-users at lists.sourceforge.net>
>         https://lists.sourceforge.net/lists/listinfo/geomoose-users
>     EditLive Enterprise is the world's most technically advanced content
>     authoring tool. Experience the power of Track Changes, Inline Image
>     Editing and ensure content is compliant with Accessibility Checking.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110616/7159b0c5/attachment.html
More information about the Geomoose-users mailing list
