[Geomoose-users] Culling Trac
Brian Fischer bfischer at houstoneng.com
Wed Sep 21 16:20:42 EDT 2011
Ok, the first bug I see in trunk is the toolbar doesn’t not show up in IE9.  Works fine in FF6.  I’m using the geomoose_dev.html file.
I see Brent previously emailed these two things as well.
     - I had to remove the trailing comma on line 579 of main.js to get Geomoose_dev to load (deja-vu).
     - IE (8 or 9) doesn't display the toolbar, but both Chrome and Firefox do.
Brian Fischer, CFM
GIS Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
Sent: Wednesday, September 21, 2011 1:53 PM
To: Brian Fischer; Brent Fraser
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Culling Trac
Trunk should probably be a discussion on the list, however, generally, bugs in trunk are not really considered bugs until an RC1 or DR1 has been stamped.
To: Brian Fischer <bfischer at houstoneng.com>; Brent Fraser <bfraser at geoanalytic.com>; Dan Little <danlittle at yahoo.com>
Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Sent: Wednesday, September 21, 2011 1:25 PM
Subject: RE: [Geomoose-users] Culling Trac
Since we are in between migrating Trac.  Where should we report bugs for the current code that is in trunk?  Or should I just hold them until OSGeo get’s trac setup for us?  I’m beginning to test things.
Brian Fischer, CFM
GIS Manager
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brian Fischer
Sent: Tuesday, September 20, 2011 9:50 PM
To: Brent Fraser; Dan Little
Once we have a 2.6 up and running I would be willing to go through them and see if they are still valid or if they can be closed.
Brian Fischer, CFM
GIS Manager
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Monday, September 19, 2011 2:11 PM
To: Dan Little
Duck,
  Six of the tickets I've submitted are still open, but I don't know if they will be fixed as a side-effect of the re-work for 2.6.  If most (all?) of the code for 2.6 is now in trunk, I could try to reproduce them....
Ticket<http://www.geomoose.org/trac/query?status=accepted&status=assigned&status=needs_work&status=new&status=reopened&status=testing&group=reporter&col=id&col=summary&order=id>
Summary<http://www.geomoose.org/trac/query?status=accepted&status=assigned&status=needs_work&status=new&status=reopened&status=testing&group=reporter&col=id&col=summary&order=summary>
#97<http://www.geomoose.org/trac/ticket/97>
Identify Attributes on a WMS not finding the feature<http://www.geomoose.org/trac/ticket/97>
#119<http://www.geomoose.org/trac/ticket/119>
Printing WMS layer does not work if requested projection different from view<http://www.geomoose.org/trac/ticket/119>
#121<http://www.geomoose.org/trac/ticket/121>
Feature Editor - Missing Required Field<http://www.geomoose.org/trac/ticket/121>
#39<http://www.geomoose.org/trac/ticket/39>
popups fail if layer coordinate system different from map coordinate system<http://www.geomoose.org/trac/ticket/39>
#98<http://www.geomoose.org/trac/ticket/98>
Identify Attributes on a WMS requires a return type of application/vnd.ogc.gml<http://www.geomoose.org/trac/ticket/98>
#5<http://www.geomoose.org/trac/ticket/5>
Editing complex polygons and lines in Internet Explorer<http://www.geomoose.org/trac/ticket/5>
Best Regards,
Brent Fraser
On 9/19/2011 12:28 PM, Dan Little wrote:
PSC,
Can we get some lists built for what Trac tickets are important and/or still apply?
I think that we should probably have two categories:
A) 2.4 bug(s) that should be fixed. This implies that a 2.4.1 release is important and should be done.
B) Bugs/Enhancements that are important for 2.6.
It may be worthwhile to categorize the other tickets or justify why they are being dropped.  I believe many will simply be subsumed by 2.6 functionality but that is not going to be universally true.
Users,
Input is also worthwhile here.
-Duck
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110921/0af3f5e3/attachment-0001.html
More information about the Geomoose-users mailing list
