[Geomoose-users] Cant get the demo data to work
Brent Fraser bfraser at geoanalytic.com
Sat Jan 14 11:48:55 EST 2012
   I think Eli gave some good advice in reply to your email on Jan 3.
But to make sure I'm on the right track to solve your problem, I need
some more info on your configuration:
Server O/S:     ?
MS4W version:      ?
GeoMoose:    v2.4
Browser:    Firefox v?
Thanks!
Best Regards,
Brent Fraser
On 1/13/2012 4:25 PM, William Lavell wrote:
> Hi so how do you suppose I can begin to solve this issue.  Where should the
> correct projection be? It is odd how I installed it exactly as the
> documentation states I should but nothing seems to be coming.  Where should
> my data be located?  How can I find the EPSG file?
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Monday, January 02, 2012 9:15 AM
> To: William Lavell
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Cant get the demo data to work
> William,
>    The fact that the buttons are rendered means the map book is being sent by
> the sever-side scripting and parsed ok by the client-side javascript.
>   Since  the map area is white and not a pink broken-image icon, mapserver is
> returning an image (I think); it just isn't rendering any the the data into
> it.  Typically this means the data is not accessible (security, path
> problems, etc), or there's a projection problem (eg it can't find
> EPSG:900913 in the epsg file).  I'd have to check past emails, but I think
> you have the epsg problem....
> Best Regards,
> Brent Fraser
>> Hi I was wondering if there is a read me or help file that can explain
>> the default settings I should use when setting up geomoose.
>> I unzipped all the packages to the c: drive on my computer and
>> installed geomoose as well as the c: drive.
>> I have checked and apache is working and so is map server
>> When I go to http://localhost/geomoose2/geomoose.html
>> it seems to work and geomoose opens but there is no data in there.
>> The html template is there and so are the tools and buttons on the top
>> as is the zoom and the ability to see the coordinates however....
>> The screen is blank There is nothing in it.
>> It seems that perhaps it is not reading the mapbook xml document.
>> Is it an issue with perhaps using python 2.4 as opposed to 2.5  ?
>> Any help would be awesome.
>> It seems like a great programme once I can get it to work. The HTML
>> side of things seems to work but just getting the scripts to actually
>> start loading the data are not working.
>> Here is print screen as well
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
