[Geomoose-users] Displaying each layer from a mapfile in a separate layer
Eli Adam eadam at co.lincoln.or.us
Mon Jun 10 10:01:08 PDT 2013
On Fri, Jun 7, 2013 at 12:09 AM, Robert R. Raiz <raizrobert at gmail.com> wrote:
> Hello all,
> Well, what I would like to do, is to have all the layers from a mapfile on a
> separate row in the interface (all status = on, aka checked), to be able to
> check and uncheck layers depending on what I want to see.
> I tried several options but I just did not find an easy way to accomplish
> this without inserting each layer separately in the map-source.
Does adding a map-source for each one work?  I think that is the intended way.
Eli
> No matter which layers I add in the  catalog for this reference, I still
> have them all nested under one checkbox;
> <map-source name="county" type="mapserver">
> <file>./test/parcels/parcels.map</file>
> <layer name="parcels" status="on"/>
> <param name="FORMAT" value="image/png;bits=8"/>
> </map-source>
> Is there a way to do this?
> Raiz Roland Robert
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
