[Geomoose-users] getProjection error - select.php
Jim Klassen klassen.js at gmail.com
Tue Jun 11 10:30:58 PDT 2013
I'm not sure Firebug would tell you.  GeoMoose JS only knows what is in the mapbook.  If you give it a group it will send a group.  The question is if the GeoMoose PHP side is handling groups correctly within MapScript.
On Jun 10, 2013, at 1:57 PM, Bistrais, Bob wrote:
> Are you positive it’s passing the GROUP name?  Firebug should be able to tell you for sure.
> From: TC Haddad [mailto:tchaddad at gmail.com]
> Sent: Monday, June 10, 2013 2:54 PM
> To: Bistrais, Bob
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] getProjection error - select.php
> Oh - but I guess an additional question is: is this really a Mapserver problem?
> It seems like GeoMoose should be passing the LAYER name to Mapserver, not the GROUP name. That would solve the problem....
> Your workaround is a good temp solution too, just more difficult to maintain.
> On Mon, Jun 10, 2013 at 11:46 AM, TC Haddad <tchaddad at gmail.com> wrote:
> Yes -I was able to test and confirm that if I explode my GROUP back into individual layers everything works again, so that is the temporary solution to the problem.
> Tanya
> On Mon, Jun 10, 2013 at 7:16 AM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> I think that’s a likely culprit (the Group issue).  AFAIK, that is not resolved, but I’m still on MapServer 6.0.2.  It would be worth checking with the experts on the MapServer project.
> Bob from Maine
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf OfTC Haddad
> Sent: Friday, June 07, 2013 6:34 PM
> To: geomoose-users at lists.osgeo.org
> Subject: [Geomoose-users] getProjection error - select.php
> I've crashed into the same issue that Bob (from Maine) posted about on the Mapserver list last September:
> http://lists.osgeo.org/pipermail/mapserver-users/2012-September/073223.html
> I was wondering if it ever got solved?
> In my version of events, I can say that the layer being queried seemed to work fine as an individual layer (yesterday), but as soon as it was combined in a GROUP with other related layers, this 500 server error occurs:
> Call to a member function getProjection() on a non-object in \htdocs\php\select.php on line 215
> This is happening with the buffered_select tool in GM 2.6.1. All layers in the group have the same projection defined in their LAYER descriptions..
> Maybe the flaw is that GM looks for the GROUP name and not for the LAYER name when it looks for the projection? and a GROUP does not (cannot?) have a projection definition?
> Tanya
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130611/c171c124/attachment-0001.html>
More information about the Geomoose-users mailing list
