[Geomoose-users] experimenting with Geomoose 3
Brent Fraser bfraser at GeoAnalytic.com
Thu Oct 26 09:05:02 PDT 2017
Hey bobb,
   1. Google maps:  not only is it not in the demo, there's no code (that I can find).  We have to use a Key with Bing so I don't think that's a problem.
   2. radio buttons: I may have to hit F12 with debug.html!
   3. Yes I saw the settings in the URL (and the "tracker" refs in the app.js), but I found the answer; it is now set in the map source def, e.g.:
     <map-source name="ags" type="ags">         <url>https://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer</url>         <layer name="NatGeo_World_Map" status="on"/>
 (sooo many things to document!)
 From: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
Sent: Thursday, October 26, 2017 9:44 AM
To:
Cc: "GeoMOOSE Users List" <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] experimenting with Geomoose 3
Hi Brent,
 One way to do it is through the URL.
 The layers are now remembered there ( as well as bbox/scale):
 https://demo.geomoose.org/master/desktop/#on=sketch/default;vector-parcels/big-money;pipelines/pipelines;parcels/parcels;parcels/parcels_points&loc=38.93151147928233;-10370006.407643707;5550786.452080398
 Jim has done quite a bit of work with setting default settings for GeoMoose via Apache as well.  We have a default MapFile set up for example that has a set of default layers set to "on".
 I believe the Google basemapping has been a problem to work with recently without a Google Map Key, and it's been purposely left out of the demo.
 bobb
     On Oct 26, 2017, at 9:35 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
Hey all,
I'm experimenting with map backgrounds in 3.0.
Is it possible to use Google maps as a background? Is it possible to use radio buttons instead of check boxes?   I've tried using
    <group title="Backgrounds" expand="true" multiple="false">
but it doesn't work.
Can I set a background layer on by default (e.g. status="on")?
Thanks!
 --  Best Regards, Brent Fraser
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
   	"C makes it easy to shoot yourself in the foot; C++ makes it harder, but when you do, it blows away your whole leg."  	- Bjarne Stroustrup
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20171026/b2275c18/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20171026/b2275c18/attachment-0001.obj>
More information about the Geomoose-users mailing list
