[Geomoose-users] experimenting with Geomoose 3
Dan Little theduckylittle at gmail.com
Thu Oct 26 09:06:21 PDT 2017
The catalog not working is likely a bug. Or at least worth discussion of
map-source vs catalog.
On Thu, Oct 26, 2017 at 11:05 AM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Hey bobb,
>   1. Google maps:  not only is it not in the demo, there's no code (that I
> can find).  We have to use a Key with Bing so I don't think that's a
> problem.
>   2. radio buttons: I may have to hit F12 with debug.html!
>   3. Yes I saw the settings in the URL (and the "tracker" refs in the
> app.js), but I found the answer; it is now set in the map source def, e.g.:
>     <map-source name="ags" type="ags">
>         <url>https://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer</url>
>         <layer name="NatGeo_World_Map" *status="on"*/>
> (sooo many things to document!)
> *From*: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
> *Sent*: Thursday, October 26, 2017 9:44 AM
> *To*:
> *Cc*: "GeoMOOSE Users List" <geomoose-users at lists.osgeo.org>
> *Subject*: Re: [Geomoose-users] experimenting with Geomoose 3
> Hi Brent,
> One way to do it is through the URL.
> The layers are now remembered there ( as well as bbox/scale):
> https://demo.geomoose.org/master/desktop/#on=sketch/
> default;vector-parcels/big-money;pipelines/pipelines;
> parcels/parcels;parcels/parcels_points&loc=38.93151147928233;-10370006.
> 407643707;5550786.452080398
> Jim has done quite a bit of work with setting default settings for
> GeoMoose via Apache as well.  We have a default MapFile set up for example
> that has a set of default layers set to “on”.
> I believe the Google basemapping has been a problem to work with recently
> without a Google Map Key, and it’s been purposely left out of the demo.
> bobb
> On Oct 26, 2017, at 9:35 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Hey all,
> I'm experimenting with map backgrounds in 3.0.
> Is it possible to use Google maps as a background?
> Is it possible to use radio buttons instead of check boxes?   I've tried
> using
>     <group title="Backgrounds" expand="true"* multiple="false"*>
> but it doesn't work.
> Can I set a background layer on by default (e.g. status="on")?
> Thanks!
> Best Regards,
> Brent Fraser
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> "C makes it easy to shoot yourself in the foot; C++ makes it harder, but
> when you do, it blows away your whole leg."  - Bjarne Stroustrup
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20171026/cd90c32f/attachment.html>
More information about the Geomoose-users mailing list
