[Geomoose-users] experimenting with Geomoose 3
Dan Little theduckylittle at gmail.com
Thu Oct 26 09:20:50 PDT 2017
Actually, what's actually *on* is the <layer> in the <map-source>.  The
status setting in the catalog was only meant to be a "helper".  The
advantage of having the status in the <map-source> is that you can turn
that layer on, seamlessly, regardless of how many places its listed in the
catalog.
That said we should likely file a bug to support 'status="on"' in the
catalog.
On Thu, Oct 26, 2017 at 11:18 AM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Hey Dan,
>   I'd prefer to have it in the Catalog since from an implementor's point
> of view, that's what you want turned on.  And if you use a single
> map-source in more than one Catalog entry it could get a little convoluted
> if it is in the map-source.
> Thanks!
> Brent
> *From*: "Dan Little" <theduckylittle at gmail.com>
> *Sent*: Thursday, October 26, 2017 10:06 AM
> *To*: "Brent Fraser" <bfraser at geoanalytic.com>
> *Cc*: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>, "GeoMOOSE
> Users List" <geomoose-users at lists.osgeo.org>
> *Subject*: Re: [Geomoose-users] experimenting with Geomoose 3
> The catalog not working is likely a bug. Or at least worth discussion of
> map-source vs catalog.
> On Thu, Oct 26, 2017 at 11:05 AM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Hey bobb,
>>   1. Google maps:  not only is it not in the demo, there's no code (that
>> I can find).  We have to use a Key with Bing so I don't think that's a
>> problem.
>>   2. radio buttons: I may have to hit F12 with debug.html!
>>   3. Yes I saw the settings in the URL (and the "tracker" refs in the
>> app.js), but I found the answer; it is now set in the map source def, e.g.:
>>     <map-source name="ags" type="ags">
>>         <url>https://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer</url>
>>         <layer name="NatGeo_World_Map" *status="on"*/>
>> (sooo many things to document!)
>> *From*: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
>> *Sent*: Thursday, October 26, 2017 9:44 AM
>> *To*:
>> *Cc*: "GeoMOOSE Users List" <geomoose-users at lists.osgeo.org>
>> Hi Brent,
>> One way to do it is through the URL.
>> The layers are now remembered there ( as well as bbox/scale):
>> https://demo.geomoose.org/master/desktop/#on=sketch/default;
>> vector-parcels/big-money;pipelines/pipelines;parcels/
>> parcels;parcels/parcels_points&loc=38.93151147928233;-
>> 10370006.407643707;5550786.452080398
>> Jim has done quite a bit of work with setting default settings for
>> GeoMoose via Apache as well.  We have a default MapFile set up for example
>> that has a set of default layers set to “on”.
>> I believe the Google basemapping has been a problem to work with recently
>> without a Google Map Key, and it’s been purposely left out of the demo.
>> bobb
>> On Oct 26, 2017, at 9:35 AM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>> Hey all,
>> I'm experimenting with map backgrounds in 3.0.
>> Is it possible to use Google maps as a background?
>> Is it possible to use radio buttons instead of check boxes?   I've tried
>> using
>>     <group title="Backgrounds" expand="true"* multiple="false"*>
>> but it doesn't work.
>> Can I set a background layer on by default (e.g. status="on")?
>> Thanks!
>> Best Regards,
>> Brent Fraser
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> "C makes it easy to shoot yourself in the foot; C++ makes it harder, but
>> when you do, it blows away your whole leg."  - Bjarne Stroustrup
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20171026/ad6962f7/attachment-0001.html>
More information about the Geomoose-users mailing list
