[GeoNode-devel] Integrity error
PERDRIEAU Mathieu Mathieu.PERDRIEAU at eau-loire-bretagne.fr
Wed Dec 13 00:48:31 PST 2017
Hello,
On my server, I put Geonode 2.5. It was installed in March 2017.
But my problem is not in the version, but an error in the Geonode code. When I add a new keyword in the documents, it wants to insert it with a depth to null. But this value must be not null in the database. And I also have the impression that the value of the path is not calculated. Do you know where these actions are done? and what modification can I make?
In addition, do you have the conceptual model of the data?
Regards
Mathieu PERDRIEAU
De : Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Envoyé : mercredi 13 décembre 2017 09:02
À : PERDRIEAU Mathieu
Cc : geonode-devel at lists.osgeo.org; geonode-users-bounces at lists.osgeo.org
Objet : Re: [GeoNode-devel] Integrity error
2.5 is not available. Do you have the 2.6? How did you install it?
2017-12-12 13:48 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr<mailto:Mathieu.PERDRIEAU at eau-loire-bretagne.fr>>:
Hi ,
Escuse me, I made a typing error. My geonode run under version 2.5. It is stable?
The error comes from the hierachialkeywords table, the depth value is null. I do not understand why.
Regards,
Mathieu PERDRIEAU
De : Simone Dalmasso [mailto:simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>]
Envoyé : mardi 12 décembre 2017 11:07
Cc : geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi, geonode 2.9 (master) is considered unstable, the suggestion is to use the stable one 2.6 or maybe the 2.7 which is well shaped. We will check this for sure before the release.
Regards
2017-12-12 9:20 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr<mailto:Mathieu.PERDRIEAU at eau-loire-bretagne.fr>>:
Hello all,
Currently I am having a problem with GeoNode. I use geonode 2.9
My issue is the following :
When I want to add a new keyword to a document I get the following error:
ERROR: A NULL value violates the NOT NULL constraint in the depth column
DETAIL: The failed line contains (71, TestDocumentV2, testdocumentv2_1,, null, 0)
This error only occurs with the documents, did you already meet it? Do you have a solution ?
Thank you
Mathieu PERDRIEAU
[http://www.eau-loire-bretagne.fr/images/image/internet/Images/signature/AELB-CAS3-Q.gif]
[Description : cid:261c336d-b2fa-429f-b771-cf2edf5f7e75]<http://www.facebook.com/pages/Agence-de-leau-Loire-Bretagne/309664692457628>  [Description : cid:image008.png at 01CDF3D6.AF65D5D0] <http://twitter.com/LoireBretagne>
Agence de l'eau Loire-Bretagne
9 avenue Buffon<https://maps.google.com/?q=9+avenue+Buffon&entry=gmail&source=g> - CS 36339 - 45063 ORLEANS CEDEX 2
Tél. : 02 38 51 73 73
Etablissement public du ministère chargé du développement durable
<http://www.eau-loire-bretagne.fr/>
Pour un bon état des rivières, lacs, nappes et littoral, ensemble, prenons soin de l'eau !
geonode-devel mailing list
geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
Simone
9 avenue Buffon - CS 36339 - 45063 ORLEANS CEDEX 2
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171213/c516dfd6/attachment-0001.html>
More information about the geonode-devel mailing list
