[GeoNode-devel] Geoserver Layers from 2.4 to 2.6 - permissions
Francesco Bartoli xbartolone at gmail.com
Fri Dec 15 14:41:25 PST 2017
GeoServer data dir is partially different so just copying wouldn’t help. I think there should be a backup/restore procedure but I haven’t tried it yet, maybe Paolo and Alessio can help here
Il giorno 15/dic/2017, alle ore 20:58, LM Admin <skeenamaps at gmail.com> ha scritto:
> Hi all,
> I recently upgraded a client's map portal from Geonode 2.4 to 2.6.  I copied the db and updated to the 2.6 schema using manage.py --fake-initial, and updatemaplayerip. I also copied the entire Geoserver data directory.  When logged in as a registered user, maps and layers work fine. However, as an anonymous user (not logged in), none of the layers render correctly in Geoserver--instead I get error tiles of class olTileImage.olImageLoadError.  In Geonode, all of these layers are set to public.
> However, new layers that I upload display correctly for both registered and anonymous users. So the permission issue is limited to layers imported from Geonode 2.4.  Given the change in Geoserver versions, and the change in authentication, is copying the entire Geoserver data directory the right thing to do? Or am I missing a step?
> Thank you,
> LM
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
