[GeoNode-devel] Geoserver Layers from 2.4 to 2.6 - permissions
LM Admin skeenamaps at gmail.com
Fri Dec 15 15:02:29 PST 2017
Thank you for the suggestions. Should I be using this guide to setup Oauth?
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/
Oauth parameters seem to be set correctly.  ./manage.py sync_geofence did
not fix the issue, however.
LM
On Fri, Dec 15, 2017 at 2:41 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> GeoServer data dir is partially different so just copying wouldn’t help. I
> think there should be a backup/restore procedure but I haven’t tried it
> yet, maybe Paolo and Alessio can help here
> Il giorno 15/dic/2017, alle ore 20:58, LM Admin <skeenamaps at gmail.com> ha
> scritto:
> > Hi all,
> > I recently upgraded a client's map portal from Geonode 2.4 to 2.6.  I
> copied the db and updated to the 2.6 schema using manage.py --fake-initial,
> and updatemaplayerip. I also copied the entire Geoserver data directory.
> When logged in as a registered user, maps and layers work fine. However, as
> an anonymous user (not logged in), none of the layers render correctly in
> Geoserver--instead I get error tiles of class
> olTileImage.olImageLoadError.  In Geonode, all of these layers are set to
> public.
> > However, new layers that I upload display correctly for both registered
> and anonymous users. So the permission issue is limited to layers imported
> from Geonode 2.4.  Given the change in Geoserver versions, and the change
> in authentication, is copying the entire Geoserver data directory the right
> thing to do? Or am I missing a step?
> > Thank you,
> > LM
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171215/e876545d/attachment.html>
More information about the geonode-devel mailing list
