[GeoNode-devel] Using geonode-updateip with a custom geonode-project
Simone Dalmasso simone.dalmasso at gmail.com
Wed Sep 13 05:01:35 PDT 2017
Thanks for the feedback, I think could make the geonode-updateip and the
geonode commands to accept a --settings flag like django-admin.py can do.
Could you please file a ticket with your issue?
Ragards
2017-09-13 11:10 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
> OK, I think I got to the bottom of this issue.
> Setting DJANGO_SETTINGS_MODULE variable wasn't working because python's
> sys.path first looks for modules in the *current working directory*, then
> looks to system-wide modules on PYTHONPATH. DJANGO_SETTINGS_MODULE is
> found on PYTHONPATH.
> In the *current working directory* for the geonode-updateip command
> (/usr/sbin) is a script called "geonode" which sys.path is finding first.
> This sets the settings to geonode.settings rather than
> mygeonodeproject.settings, before django ever looks on PYTHONPATH. This
> one:
> https://github.com/GeoNode/geonode/blob/2.6.x/package/suppor
> t/geonode.binary
> I modified this file to use mygeonodeproject.settings and everything works
> as expected now, thanks for the help.
> I don't know how to structure a Pull Request to address this when using
> geonode-project. I've simply updated my deployment scripts to do this at
> build-time. Thoughts welcome here.
> regards
> Dave
> On 8 September 2017 at 17:11, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
>> Yes this is the behaviour that I would expect with the current setup.
>> geonode-updateip is using the geonode default settings because is in the
>> geonode root. While python manage.py shell from your project correctly sets
>> your project settings.
>> You could try to set the DJANGO_SETTINGS_MODULE as a permanent
>> environment variable for root (added in home/root/.bashrc or bash_profile
>> for example.
>> 2017-09-08 14:56 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>> Hi Rob  - let me have a look at this concept once I solve this immediate
>>> challenge :)
>>> Hi Simone,
>>> OK, so I tested this and
>>> os.environ['DJANGO_SETTINGS_MODULE'] = 'mygeonodeproject.settings'
>>> works to set the settings module correctly. We were correct -
>>> fixoauthuri.py was pulling settings from geonode.settings not
>>> mygeonodeproject.settings. But this doesn't solve the issue unfortunately.
>>> It's still importing the people.profile model from the local database, not
>>> the remote one.
>>> To further debug, I opened the django shell as my geonode user (in my
>>> case it's "ubuntu")
>>> from /home/ubuntu/mygeonodeproject, and ran the commands from
>>> fixoauthuri.py. This worked fine - they pick up my superuser created on the
>>> remote database.
>>> So, this leads me to believe the problem lies with fixoauthuri.py being
>>> run as "root" user when called using "sudo geonode-updateip myIpAddress".
>>> But I'm stuck as to further reasons why this is the problem.
>>> To be specific:
>>> When I use
>>> from geonode.people.models import Profile
>>> as *root from "sudo geonode-updateip"*, it imports Profile from the
>>> local database.
>>> When I use
>>> as *ubuntu from the shell,* it imports Profile from the remote
>>> database.
>>> And just for completeness, when I use
>>> as *root from the shell *("sudo python manage.py shell"), it imports
>>> Profile from the remote database.
>>> Any ideas how to remedy this one?
>>> On 8 September 2017 at 10:59, Simone Dalmasso <simone.dalmasso at gmail.com
>>> > wrote:
>>>> Hi Dave,
>>>> good catch, we need to fix this. I guess an approach like manage.py is
>>>> using https://github.com/GeoNode/geonode-project/blob/2.6/manage.py#L10,
>>>> added before the import could work but needs to be tested...
>>>> Let me know
>>>> 2017-09-07 18:32 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>>>> Hi Geonode Devs,
>>>>> I'm using geonode 2.6.3 installed by apt-get on a fresh ubuntu 16.04
>>>>> instance.
>>>>> On top of this I install geonode-project, and customise settings.py in
>>>>> mygeonodeproject.
>>>>> This works fine if I use the postgres database that apt-get
>>>>> automatically installs locally on my geonode server.
>>>>> However, when I go to swap out this local database with a remote one
>>>>> (it's on AWS RDS), it's all good until the command "sudo geonode-updateip
>>>>> mygeonodeproject.com" tells me I don't have a superuser created (I
>>>>> do, but it's on the remote database, created using the manage.py command in
>>>>> mygeonodeproject folder).
>>>>> When I drill into this a bit deeper, it appears to come down to this
>>>>> line:
>>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>>> anagement/commands/fixoauthuri.py#L33
>>>>> This line ("from django.conf import settings") is pulling in models
>>>>> from the local geonode database, not the remote RDS database I'm using for
>>>>> mygeonodeproject.
>>>>> What am I doing wrong here, and what is the best way to import my
>>>>> custom project into this command rather than the globally installed
>>>>> geonode, when using "from django.conf import settings"?
>>>>> thanks for any help
>>>>> regards
>>>>> Dave
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170913/124f1123/attachment.html>
More information about the geonode-devel mailing list
