[GeoNode-devel] Help
Pablo Masera pablomasera83 at gmail.com
Fri Mar 23 16:28:23 PDT 2018
Dear folks,
We are building a spatial data infrastructure, based on geonode working on
a server we have rented. The problem is that, although we have been able to
correctly install the docker modules, from the official container, we can't
operate the main page of our project (the basic one of geonode), geoserver
or postgis, to enter remotely from the browser, pgadmin or qgis.
We are trying to have a fully functional Geonode instance and after
successfully installing *Docker* on a *Ubuntu 16.04 LTS (Xenial)* we
ran docker-compose
up --build with the following updated/modified *"docker-compose.yml"* file:
version: '2.1'
services:
  db:
    image: geonode/postgis:9.6
    restart: unless-stopped
    container_name: db4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: db
        org.geonode.instance.name: geonode
    volumes:
      - dbdata:/var/lib/postgresql/data
      - dbbackups:/pg_backups
    env_file:
      - ./scripts/docker/env/production/db.env
  elasticsearch:
    image: elasticsearch
    container_name: elasticsearch4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: elasticsearch
  rabbitmq:
    image: rabbitmq
    container_name: rabbitmq4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: rabbitmq
  django:
    image: geonode/geonode:latest
    container_name: django4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: django
    depends_on:
      - db
      - elasticsearch
      - rabbitmq
    command: django-admin.py runserver 0.0.0.0:8000 --settings=geonode.settings
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
    env_file:
      - ./scripts/docker/env/production/django.env
  celery:
    container_name: celery4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: celery
    depends_on:
      - db
      - elasticsearch
      - rabbitmq
    command: celery worker --app=geonode.celery_app:app -B -l INFO
    volumes:
    env_file:
      - ./scripts/docker/env/production/celery.env
  consumers:
    container_name: consumers4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: consumers
    depends_on:
      - rabbitmq
      - db
      - elasticsearch
    command: python manage.py runmessaging
    volumes:
    env_file:
  geoserver:
    image: geonode/geoserver:2.12.x
    container_name: geoserver4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: geoserver
    depends_on:
      - db
    volumes:
      - geoserver-data-dir:/geoserver_data/data
    env_file:
      - ./scripts/docker/env/production/geoserver.env
  geonode:
    image: geonode/nginx:geoserver
    container_name: nginx4${COMPOSE_PROJECT_NAME}
    stdin_open: true
    # tty: true
    labels:
        org.geonode.component: nginx
    depends_on:
      - django
      - geoserver
    ports:
      - "8888:80"
    expose:
      - "80"
  data-dir-conf:
    image: geonode/geoserver_data:2.12.x
    restart: on-failure
    container_name: gsconf4${COMPOSE_PROJECT_NAME}
    labels:
        org.geonode.component: conf
    command: /bin/true
    volumes:
volumes:
  geoserver-data-dir:
    external: false
  dbdata:
    external: false
  dbbackups:
    external: false
After a couple of test runs we have not been able to connect to *postgis*,
neither to the *geoserver* admin page on
<server-ip-address>:8888/geoserver/web nor the default *geonode* main page.
1st Run
docker ps
docker exec -it db4geonode bash
psql -h <server-ip-address> -p 5432 -U postgres
2nd Run
cd ./home/geonode/
docker-compose down
docker-compose up
docker ps
3rd Run
cd ./home/geonode/
docker-compose down
docker-compose up
docker ps
su postgres
psql
CREATE DATABASE first_test_db;
\l
​we made the changes on the .env files suggested by Francesco Bartoli
This is our docker ps:
docker ps
CONTAINER ID        IMAGE                      COMMAND
 CREATED             STATUS              PORTS
       NAMES
186dc28b244b        geonode/nginx:geoserver    "nginx -g 'daemon of…"
 39 minutes ago      Up 39 minutes       0.0.0.0:8888->80/tcp
       nginx4geonode
8860c7ac99ab        geonode/geonode:latest     "/usr/src/app/entryp…"
 39 minutes ago      Up 39 minutes       8000/tcp
       celery4geonode
27680b9757e3        geonode/geonode:latest     "/usr/src/app/entryp…"
       django4geonode
a282f2cb3896        geonode/geonode:latest     "/usr/src/app/entryp…"
       consumers4geonode
6eacf6568689        geonode/geoserver:2.12.x   "/usr/local/tomcat/t…"
 39 minutes ago      Up 39 minutes       8080/tcp
       geoserver4geonode
8e7fbf748088        geonode/postgis:9.6        "docker-entrypoint.s…"
 39 minutes ago      Up 39 minutes       5432/tcp
       db4geonode
94bad42ba148        rabbitmq                   "docker-entrypoint.s…"
 39 minutes ago      Up 39 minutes       4369/tcp, 5671-5672/tcp,
25672/tcp   rabbitmq4geonode
351485c47fef        elasticsearch              "/docker-entrypoint.…"
 39 minutes ago      Up 39 minutes       9200/tcp, 9300/tcp
       elasticsearch4geonode
All containers are running ok
Our .env files are this:
Celery.env
GEONODE_INSTANCE_NAME=geonode
GEONODE_LB_HOST_IP=190.111.252.249
GEONODE_LB_PORT=80
DATABASE_URL=postgres://postgres:postgres@db:5432/postgres
DEFAULT_BACKEND_DATASTORE=datastore
GEONODE_DATABASE=geonode
GEONODE_DATABASE_PASSWORD=geonode
GEONODE_GEODATABASE=geonode_data
GEONODE_GEODATABASE_PASSWORD=geonode_data
BROKER_URL=amqp://guest:guest@rabbitmq:5672/
DJANGO_SETTINGS_MODULE=geonode.settings
ALLOWED_HOSTS=['django',]
DOCKER_ENV=production
CELERY_CMD=celery worker --app=geonode.celery:app
--broker=amqp://guest:guest@rabbitmq:5672/ -B -l INFO
IS_CELERY=true
C_FORCE_ROOT=1
GEOSERVER_PUBLIC_LOCATION=http://geonode/geoserver/
GEOSERVER_LOCATION=http://geonode/geoserver/
SITEURL=http://geonode/
django.env
GEONODE_LB_PORT=80
UWSGI_CMD=uwsgi --ini /usr/src/app/uwsgi.ini
IS_CELERY=false
C_FORCE_ROOT=1
And geoserver.env
DOCKERHOST
GEONODE_LB_PORT=80
PUBLIC_PORT=80
DOCKER_HOST_IP=172.17.0.1
Don´t know what we are doing wrong. Firewall is not the problem, it seems,
cause we disable it...
We would appreciate all the possible help that you might be able to provide
us with.
*Pablo Masera*
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180323/04358f1f/attachment-0001.html>
More information about the geonode-devel mailing list
