[GeoNode-devel] 2.8.0 - ACCOUNT_APPROVAL_REQUIRED setting appears not to have effect
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu May 31 01:20:56 PDT 2018
Hi Dave,
yes, it is possible that this feature has not yet completed.
Will try to take look as soon as I can.
2018-05-30 18:03 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
> Hi Alessio,
> Yes, the email backend is already configured, and it works on my site for
> both pinax notifications and the standard account emails.
> I was expecting to see an email template for the email from geonode to the
> admin, stored in this folder:
> https://github.com/GeoNode/geonode/tree/2.8.0/geonode/
> templates/account/email
> But there is no template? and the  moderator_contacted
> <https://github.com/GeoNode/geonode/blob/d41328bfddbe3d5820338f455c5767b2067d759d/geonode/views.py#L151> function
> seems to just get the user model to display the email address in the
> template rather than actually sending anything.
> I don't think this is meant to be covered by pinax, but I had a look there
> and couldn't find anything either.
> Is it possible this feature has not yet been implemented?
> On 30 May 2018 at 19:12, Alessio Fabiani <alessio.fabiani at geo-solutions.it
> > wrote:
>> Hi,
>> in order to receive emails you need to configure the email backend too,
>> which is disabled by default
>> 2018-05-30 16:53 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>> Hi all,
>>> I'm using 2.8.0.
>>> The ACCOUNT_APPROVAL_REQUIRED setting appears to work in that it stops a
>>> new user's account being immediately active, but geonode does not appear to
>>> be emailing the admins to let them know, resulting in some pretty lonely
>>> users not being onboarded.
>>> Looking through the code, I was expecting a notification to be sent to
>>> the admins from here:
>>> Am I missing something here, or does this need a fix?
>>> Thanks
>>> Dave
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A -
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>  Massarosa
>> (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180531/1fe63107/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180531/1fe63107/attachment-0001.png>
More information about the geonode-devel mailing list
