[GeoNode-users] ubuntu 12.04 LTS error installation
Simone Dalmasso simone.dalmasso at gmail.com
Wed Apr 22 10:36:36 PDT 2015
I will test tomorrow what's going on with the 12.04. This is the first time
that I hear such error... Thanks for reporting.
Il mercoledì 22 aprile 2015, Vladimiro Bellini <vlasvlasvlas at gmail.com> ha
scritto:
> Hi,
> yep the Ubuntu 12.04 its a fresh brand new system.
> and i do was following Ubuntu 12.04 online guides....
> https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
> maybe Ubuntu 12.04 guides must be modified, because they really dont work..
> i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at
> all..
> i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
> thanks for the quick answer :)
> Vladimiro Bellini              __
> \ /| _ _|. _ . _ |__) _||. _ .
> El 22 de abril de 2015, 14:15, Simone Dalmasso <simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> escribió:
>> Hi Vladimiro,
>> thanks for posting here.
>> is the ubuntu you are using a brand new system?
>> Are you aware that there is the geonode 2.4 beta available for ubuntu
>> 14.04 which has many many improvements from the 2.0?
>> It's a beta but quite stable and we will not change its data model before
>> the official release so any update should be smooth.
>> To install it on 14.04 use ppa:geonode/testing instead of
>> ppa:geonode/release.
>> Regards
>> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com
>> <javascript:_e(%7B%7D,'cvml','vlasvlasvlas at gmail.com');>>:
>>> Hi,
>>> i was installing geonode using ubuntu 12.04.5 LTS
>>> I'm following this guide:
>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>>> i have dependecies issue right on start:
>>> root at ubuntu:/# cat /etc/issue
>>> Ubuntu 12.04.5 LTS \n \l
>>> root at ubuntu:/#
>>> root at ubuntu:/# sudo apt-get install python-software-properties
>>> Leyendo lista de paquetes... Hecho
>>> Creando árbol de dependencias
>>> Leyendo la información de estado... Hecho
>>> python-software-properties ya está en su versión más reciente.
>>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>>> You are about to add the following PPA to your system:
>>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>>> Press [ENTER] to continue or ctrl-c to cancel adding it
>>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>>> gpg: Cantidad total procesada: 1
>>> gpg:               importadas: 1  (RSA: 1)
>>> OK
>>> root at ubuntu:/#
>>> root at ubuntu:/# sudo apt-get update
>>> Obj http://ppa.launchpad.net precise Release.gpg
>>> Obj http://es.archive.ubuntu.com precise Release.gpg
>>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>>> Obj http://ppa.launchpad.net precise/main Sources
>>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>>> Obj http://ppa.launchpad.net precise/main i386 Packages
>>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>>> Obj http://ppa.launchpad.net precise/main Translation-en
>>> Obj http://es.archive.ubuntu.com precise/main Sources
>>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>>> Descargados 2.535 kB en 6seg. (395 kB/s)
>>> root at ubuntu:/#
>>> and now.. the error !
>>> root at ubuntu:/# sudo apt-get install geonode
>>> No se pudieron instalar algunos paquetes. Esto puede significar que
>>> usted pidió una situación imposible o, si está usando la distribución
>>> inestable, que algunos paquetes necesarios no han sido creados o han
>>> sido movidos fuera de Incoming.
>>> La siguiente información puede ayudar a resolver la situación:
>>> Los siguientes paquetes tienen dependencias incumplidas:
>>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>>                     geoserver pero no va a instalarse
>>>            Depende: python-virtualenv pero no es instalable
>>>            Depende: python-pyproj pero no es instalable
>>>            Depende: python-shapely pero no es instalable
>>>            Depende: gdal-bin pero no es instalable
>>>            Depende: libgeos-dev pero no es instalable
>>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>>                     postgresql-8.4-postgis pero no es instalable
>>>            Depende: python-gdal pero no es instalable
>>>            Depende: libproj-dev pero no es instalable
>>>            Depende: python-django-downloadview pero no va a instalarse
>>>            Depende: python-django-extensions pero no va a instalarse
>>>            Depende: python-django-user-accounts pero no va a instalarse
>>>            Depende: python-pycsw pero no va a instalarse
>>>            Depende: python-paver pero no va a instalarse
>>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>>            Depende: python-multipartposthandler pero no es instalable
>>>            Recomienda: python-gisdata pero no va a instalarse
>>>            Recomienda: transifex-client pero no es instalable
>>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>>> root at ubuntu:/#
>>> anyone know how this could be?
>>> thanks!
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/ec450d48/attachment-0001.html>
More information about the geonode-users mailing list
