[GeoNode-users] ubuntu 12.04 LTS error installation
Vladimiro Bellini vlasvlasvlas at gmail.com
Wed Apr 22 10:43:26 PDT 2015
Simone, i'm testing with Ubuntu 14.04 + ppa:geonode/testing and
installation process started OK.
is now installing..
thanks a lot!
ill report if the whole process finish OK.
thanks again,
Vladimiro Bellini.
Vladimiro Bellini              __
\ /| _ _|. _ . _ |__) _||. _ .
2015-04-22 14:36 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> I will test tomorrow what's going on with the 12.04. This is the first
> time that I hear such error... Thanks for reporting.
> Il mercoledì 22 aprile 2015, Vladimiro Bellini <vlasvlasvlas at gmail.com>
> ha scritto:
>> Hi,
>> yep the Ubuntu 12.04 its a fresh brand new system.
>> and i do was following Ubuntu 12.04 online guides....
>> https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
>> maybe Ubuntu 12.04 guides must be modified, because they really dont
>> work..
>> i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at
>> all..
>> i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
>> thanks for the quick answer :)
>> El 22 de abril de 2015, 14:15, Simone Dalmasso <simone.dalmasso at gmail.com
>> > escribió:
>>> Hi Vladimiro,
>>> thanks for posting here.
>>> is the ubuntu you are using a brand new system?
>>> Are you aware that there is the geonode 2.4 beta available for ubuntu
>>> 14.04 which has many many improvements from the 2.0?
>>> It's a beta but quite stable and we will not change its data model
>>> before the official release so any update should be smooth.
>>> To install it on 14.04 use ppa:geonode/testing instead of
>>> ppa:geonode/release.
>>> Regards
>>> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>>>> Hi,
>>>> i was installing geonode using ubuntu 12.04.5 LTS
>>>> I'm following this guide:
>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>>>> i have dependecies issue right on start:
>>>> root at ubuntu:/# cat /etc/issue
>>>> Ubuntu 12.04.5 LTS \n \l
>>>> root at ubuntu:/#
>>>> root at ubuntu:/# sudo apt-get install python-software-properties
>>>> Leyendo lista de paquetes... Hecho
>>>> Creando árbol de dependencias
>>>> Leyendo la información de estado... Hecho
>>>> python-software-properties ya está en su versión más reciente.
>>>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>>>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>>>> You are about to add the following PPA to your system:
>>>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>>>> Press [ENTER] to continue or ctrl-c to cancel adding it
>>>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>>>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>>>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>>>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>>>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>>>> gpg: Cantidad total procesada: 1
>>>> gpg:               importadas: 1  (RSA: 1)
>>>> OK
>>>> root at ubuntu:/#
>>>> root at ubuntu:/# sudo apt-get update
>>>> Obj http://ppa.launchpad.net precise Release.gpg
>>>> Obj http://es.archive.ubuntu.com precise Release.gpg
>>>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>>>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>>>> Obj http://ppa.launchpad.net precise/main Sources
>>>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>>>> Obj http://ppa.launchpad.net precise/main i386 Packages
>>>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>>>> Obj http://ppa.launchpad.net precise/main Translation-en
>>>> Obj http://es.archive.ubuntu.com precise/main Sources
>>>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>>>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>>>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>>>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>>>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>>>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>>>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>>>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>>>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>>>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>>>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>>>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>>>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>>>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>>>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>>>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>>>> Descargados 2.535 kB en 6seg. (395 kB/s)
>>>> root at ubuntu:/#
>>>> and now.. the error !
>>>> root at ubuntu:/# sudo apt-get install geonode
>>>> No se pudieron instalar algunos paquetes. Esto puede significar que
>>>> usted pidió una situación imposible o, si está usando la distribución
>>>> inestable, que algunos paquetes necesarios no han sido creados o han
>>>> sido movidos fuera de Incoming.
>>>> La siguiente información puede ayudar a resolver la situación:
>>>> Los siguientes paquetes tienen dependencias incumplidas:
>>>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>>>                     geoserver pero no va a instalarse
>>>>            Depende: python-virtualenv pero no es instalable
>>>>            Depende: python-pyproj pero no es instalable
>>>>            Depende: python-shapely pero no es instalable
>>>>            Depende: gdal-bin pero no es instalable
>>>>            Depende: libgeos-dev pero no es instalable
>>>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>>>                     postgresql-8.4-postgis pero no es instalable
>>>>            Depende: python-gdal pero no es instalable
>>>>            Depende: libproj-dev pero no es instalable
>>>>            Depende: python-django-downloadview pero no va a instalarse
>>>>            Depende: python-django-extensions pero no va a instalarse
>>>>            Depende: python-django-user-accounts pero no va a instalarse
>>>>            Depende: python-pycsw pero no va a instalarse
>>>>            Depende: python-paver pero no va a instalarse
>>>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>>>            Depende: python-multipartposthandler pero no es instalable
>>>>            Recomienda: python-gisdata pero no va a instalarse
>>>>            Recomienda: transifex-client pero no es instalable
>>>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>>>> root at ubuntu:/#
>>>> anyone know how this could be?
>>>> thanks!
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/7b39a733/attachment-0001.html>
More information about the geonode-users mailing list
