[GeoNode-users] ubuntu 12.04 LTS error installation
Vladimiro Bellini vlasvlasvlas at gmail.com
Wed Apr 22 11:18:52 PDT 2015
Installation with ubuntu 14.04 + ppa:geonode/testing works like charm
thanks a lot! :)
Vladimiro Bellini              __
\ /| _ _|. _ . _ |__) _||. _ .
2015-04-22 14:43 GMT-03:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
> Simone, i'm testing with Ubuntu 14.04 + ppa:geonode/testing and
> installation process started OK.
> is now installing..
> thanks a lot!
> ill report if the whole process finish OK.
> thanks again,
> Vladimiro Bellini.
> 2015-04-22 14:36 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> I will test tomorrow what's going on with the 12.04. This is the first
>> time that I hear such error... Thanks for reporting.
>> Il mercoledì 22 aprile 2015, Vladimiro Bellini <vlasvlasvlas at gmail.com>
>> ha scritto:
>>> Hi,
>>> yep the Ubuntu 12.04 its a fresh brand new system.
>>> and i do was following Ubuntu 12.04 online guides....
>>> https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
>>> maybe Ubuntu 12.04 guides must be modified, because they really dont
>>> work..
>>> i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at
>>> all..
>>> i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
>>> thanks for the quick answer :)
>>> El 22 de abril de 2015, 14:15, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> escribió:
>>>> Hi Vladimiro,
>>>> thanks for posting here.
>>>> is the ubuntu you are using a brand new system?
>>>> Are you aware that there is the geonode 2.4 beta available for ubuntu
>>>> 14.04 which has many many improvements from the 2.0?
>>>> It's a beta but quite stable and we will not change its data model
>>>> before the official release so any update should be smooth.
>>>> To install it on 14.04 use ppa:geonode/testing instead of
>>>> ppa:geonode/release.
>>>> Regards
>>>> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>>>>> Hi,
>>>>> i was installing geonode using ubuntu 12.04.5 LTS
>>>>> I'm following this guide:
>>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>>>>> i have dependecies issue right on start:
>>>>> root at ubuntu:/# cat /etc/issue
>>>>> Ubuntu 12.04.5 LTS \n \l
>>>>> root at ubuntu:/#
>>>>> root at ubuntu:/# sudo apt-get install python-software-properties
>>>>> Leyendo lista de paquetes... Hecho
>>>>> Creando árbol de dependencias
>>>>> Leyendo la información de estado... Hecho
>>>>> python-software-properties ya está en su versión más reciente.
>>>>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>>>>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>>>>> You are about to add the following PPA to your system:
>>>>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>>>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>>>>> Press [ENTER] to continue or ctrl-c to cancel adding it
>>>>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>>>>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>>>>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>>>>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>>>>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>>>>> gpg: Cantidad total procesada: 1
>>>>> gpg:               importadas: 1  (RSA: 1)
>>>>> OK
>>>>> root at ubuntu:/#
>>>>> root at ubuntu:/# sudo apt-get update
>>>>> Obj http://ppa.launchpad.net precise Release.gpg
>>>>> Obj http://es.archive.ubuntu.com precise Release.gpg
>>>>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>>>>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>>>>> Obj http://ppa.launchpad.net precise/main Sources
>>>>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>>>>> Obj http://ppa.launchpad.net precise/main i386 Packages
>>>>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>>>>> Obj http://ppa.launchpad.net precise/main Translation-en
>>>>> Obj http://es.archive.ubuntu.com precise/main Sources
>>>>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>>>>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>>>>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>>>>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>>>>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>>>>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>>>>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>>>>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>>>>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>>>>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>>>>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>>>>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>>>>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>>>>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>>>>> Descargados 2.535 kB en 6seg. (395 kB/s)
>>>>> root at ubuntu:/#
>>>>> and now.. the error !
>>>>> root at ubuntu:/# sudo apt-get install geonode
>>>>> No se pudieron instalar algunos paquetes. Esto puede significar que
>>>>> usted pidió una situación imposible o, si está usando la distribución
>>>>> inestable, que algunos paquetes necesarios no han sido creados o han
>>>>> sido movidos fuera de Incoming.
>>>>> La siguiente información puede ayudar a resolver la situación:
>>>>> Los siguientes paquetes tienen dependencias incumplidas:
>>>>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>>>>                     geoserver pero no va a instalarse
>>>>>            Depende: python-virtualenv pero no es instalable
>>>>>            Depende: python-pyproj pero no es instalable
>>>>>            Depende: python-shapely pero no es instalable
>>>>>            Depende: gdal-bin pero no es instalable
>>>>>            Depende: libgeos-dev pero no es instalable
>>>>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>>>>                     postgresql-8.4-postgis pero no es instalable
>>>>>            Depende: python-gdal pero no es instalable
>>>>>            Depende: libproj-dev pero no es instalable
>>>>>            Depende: python-django-downloadview pero no va a instalarse
>>>>>            Depende: python-django-extensions pero no va a instalarse
>>>>>            Depende: python-django-user-accounts pero no va a instalarse
>>>>>            Depende: python-pycsw pero no va a instalarse
>>>>>            Depende: python-paver pero no va a instalarse
>>>>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>>>>            Depende: python-multipartposthandler pero no es instalable
>>>>>            Recomienda: python-gisdata pero no va a instalarse
>>>>>            Recomienda: transifex-client pero no es instalable
>>>>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>>>>> root at ubuntu:/#
>>>>> anyone know how this could be?
>>>>> thanks!
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/bba1783e/attachment-0001.html>
More information about the geonode-users mailing list
