[GeoNode-users] geonode customization
Jeffrey Johnson ortelius at gmail.com
Mon Nov 9 07:00:41 PST 2015
Hi Eugenio,
Im going to let Tom or one of the other Metadata Gurus answer all the
metadata questions, but I can say that the best way to customize the
front end of your geonode is to use template project here
https://github.com/GeoNode/geonode-project and then edit the base
templates and css in your project using bootstrap. If you want to add
new categories or topics to your data, it is better to use something
like keywords to manage that rather than changing the standard
metadata models. You can then leverage the search engine / api to
change how these are presented in the UI.
Hope that helps,
Jeff
On Mon, Nov 9, 2015 at 6:11 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Hi to everybody,
> thanks to everybody, in particular with who follow me during geonode my
> installation for production.
> Now I can say that the most important functionalities are working (including
> save map who gave me a lot of troubles).
> Currently I'm going to work to customize my geonode installation exploiting
> some already running services
> managed by my organization.
> Firstly I read the guide:
> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
> but I wonder if somebody can suggest me other reference, for instance on
> bootstrap usage in geonode or a guide to customize the portal.
> After that I would like to know if I can manage another group of categories,
> let's call them 'topics', which details better the layers/maps/documents I'm
> going to upload/use.
> Eventually I wonder I does the metadata management in geonode work. I
> understand that all layers loaded and maps created are related to metadata
> saved in pycsw default system. I have an already running geonetwork
> containing about 50 metadata, I saw I can use my metadata engine as
> catalogue by configuring it in the local_setting.py, but I guess geonode
> will use the catalogue set to store new metadata, what happens to those
> already loaded in my external engine? Is it possible to have them listed? If
> not can I connect my metadata engine as CSW service by using external
> service setup? In that way am I able to list the metadata (and the
> attributes) somewhere in geonode?
> Last thing is a little issue on downloading the metadata in different
> format: two quwstions: 1) I got an error 'server not found', that's why I
> guess there is something wrong on the URL call for the catalogue since the
> URL is:
> http://my_server_namecatalogue/csw?outputschema=http%3A%2F%2Fwww.isotc211.org%2F2005%2Fgmd&service=CSW&request=GetRecordById&version=2.0.2&elementsetname=full&id=15305b80-86d5-11e5-8e7f-5254002700a7
> As you can see after http:// I have my_server_namecatalogue I think it could
> be an error having my server name attached to catalogue, isn't it?
> Then I wonder if it is possible to download the metadata in INSPIRE format
> or other specific.
> Thanks for now,
> best
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
