[GeoNode-users] shapefile size restriction
Lautaro Silva jlautarosilva at gmail.com
Fri Oct 2 14:08:24 PDT 2015
Hello all
I'm running GeoNode configured datastore in settings.py to load al the
features into a postgis database.
That is working almost ok, but when i am trying to upload a Shapefile over
100mb i get errors like:
"An exception occurred loading data to PostGIS-
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request PUT
/geoserver/rest/workspaces/geonode/datastores/datastore/file.shp.
Reason: Error reading from remote server"
and some times this one:
"An exception occurred loading data to PostGIS- java.lang.RuntimeException:
java.io.IOException: Error occured calculating bounds for predios_rural"
Had anyone experienced similar problems with big files?
It is posible that i am doing something wrong?
Thanks in advance
*Lautaro  Silva <http://lautarosilva.cl>*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151002/70c68896/attachment.html>
More information about the geonode-users mailing list
