[GeoNode-users] opening up client side of geonode server on ubuntu error
Levi Westerveld levi.westerveld at gmail.com
Fri Apr 8 06:31:22 PDT 2016
hmmm, where should I look for those?
On Fri, Apr 8, 2016 at 3:25 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Not very clear from the log. But something went wrong with the migration I
> guess. Do you layer tables in the db have a column named 'id'?
> 2016-04-08 15:14 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>> Hi,
>> The file in questions is attached to this email.
>> Thank you,
>> Levi
>> On Fri, Apr 8, 2016 at 3:07 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, what error do you get on /var/logs/apache2/error.log?
>>> 2016-04-08 14:47 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>>> Hello,
>>>> We just recently managed to transfer our data from 2.0 to 2.4, but
>>>> after trying to open up our server so that it can be accessed through a
>>>> normal web browser online, we are getting an Internal Server Error. (
>>>> http://opengeo.grida.no/) Is there a tutorial out there on the steps
>>>> to take to set the server so that it can be accessed in a web browser?
>>>> When the geonode was running internally, we could also not access the
>>>> geoserver (each time I would get a tomcat7 error message). Is the geoserver
>>>> something that should be installed independently from the geonode in the
>>>> terminal? Perhaps that is the source of the initial issue?
>>>> Many thanks,
>>>> Levi
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Levi Westerveld
> Simone
Levi Westerveld
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160408/26466e1b/attachment.html>
More information about the geonode-users mailing list
