[GeoNode-users] Styles not stylin'
Paolo Corti pcorti at gmail.com
Tue May 3 13:07:32 PDT 2016
Hi
I am not familiar with the installation from package in Ubuntu but one
of the possible things that could take to the behavior you are
describing it is if you changed the default password for the geoserver
administrative user. Styles are changed from GeoNode using that user
and calling the GeoServer REST API.
In such a case you need to change it accordingly in this location (or
even better with a local settings file):
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L505
hope it helps
p
On Tue, Apr 26, 2016 at 9:59 AM, Cliff Patterson
<cliffpatterson at gmail.com> wrote:
> Greetings Geonode Users!
> I'm new to Geonode, but familiar with Geoserver and PostGIS. I installed
> Geonode from the ppa this week, and I am having a number of problems getting
> a few critical components working. I am running Geonode on Ubuntu Server
> 14.04.4 LTS.
> I'll start this post with what I consider the top priority in my world at
> the moment -- styling layers.
> Basically, if I set a layer style in Geoserver, it appears in Geonode's
> GeoExplorer with that style when I run "geonode updatelayers", but I am
> unable to change the style from within GeoNode. If I make any edits in the
> map view, those changes are not made either to the mapped layer and they are
> not saved to geoserver. Basically, I have to completely remove a layer from
> Geoserver and re-add it if I want to make any changes to a layer's style.
> That doesn't seem right.
> Next, if I change the style in Geoserver, that style is not changed in
> GeoNode. No updates are made to the GeoNode layers (except in the thumbnail
> for some reason). The layer will always display in its original style on a
> map. It is almost as though there is a cache somewhere that needs to be
> cleared (I cleared GWC, but that did nothing). I updated layers with
> "geonode updatelayers" and restarted Apache. No change.
> Note that I'm having these problems with both shapefile and PG/PostGIS
> layers.
> Can anyone point me in the right direction to get styles working with
> GeoNode?
> Big thanks!
> Cliff
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
