[GeoNode-users] How to increase the size of GeoExplorer component in Layers section?
Benjamin Ducke benducke at fastmail.fm
Mon May 23 23:55:40 PDT 2016
Hi Simone,
Thanks for you advice.
I also suspect that there is something going
wrong with the Apache config or browser cache.
I am a bit frustrated that I cannot seem to
dig up any documentation on "portalConfig",
because I think that is a powerful configuration
mechanism which could provide a lot of the
features I am looking for (incl. the layer tree
mentioned in my other email).
I will investigate this further and then report
back to this list once I figured it out.
Cheers,
Ben
On 24/05/16 07:52, Simone Dalmasso wrote:
> Hi, that "height" is the correct place. No need to restart apache
> because is just a template. If the change id not take effect then could
> it be that your template is not the one served by apache? if you inspect
> the page can you see your height in there?
> 2016-05-23 19:38 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>>:
>     Thanks for the pointer.
>     I assume you refer to this config object:
>       portalConfig: {
>                         renderTo: "preview_map",
>                         height: 400
>     I have changed "height" and restarted Apache but no effect.
>     Do I have to add something to "portalConfig"?
>     Actually, I have not been able to find any documentation on
>     the possible contents of "portalConfig". Do you have a URL
>     for the official docs?
>     Thanks,
>     Ben
>     Benjamin Ducke
>     {*} Geospatial Consultant
>     {*} GIS Developer
>       benducke AT fastmail.fm <http://fastmail.fm>
>     On Mon, May 23, 2016, at 18:34, Jeffrey Johnson wrote:
>     https://github.com/GeoNode/geonode/blob/master/geonode/layers/templates/layers/layer_geoext_map.html
>     > On Mon, May 23, 2016 at 9:29 AM, Benjamin Ducke
>     <benducke at fastmail.fm <mailto:benducke at fastmail.fm>>
>     > wrote:
>     > > Hi All --
>     > > Is there an easy way to increase the size of the embedded
>     > > GeoExplorer layer viewer?
>     > > I suppose it must be done in some template, but I cannot
>     > > seem to find the right one.
>     > > Any hints much appreciated.
>     > > Best,
>     > > Ben
>     > > _______________________________________________
>     > > geonode-users mailing list
>     > > geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     > > http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Dr. Benjamin Ducke
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
More information about the geonode-users mailing list
