[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 10 05:39:26 PDT 2017
I followed all the istructions in the tutorial you send me.
Is there a way to correct these errors using a command (i.e sudo
geonode-updateip localhost:8001)?
2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> How did you perform the installation?
> You were originally receive that error because GEOSERVER_PUBLIC_LOCATION
> is wrong. It should be:
> 'http://localhost:8001/geoserver'
> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
> GEOSERVER_LOCATION = os.getenv(
>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
> From /etc/geonode/local_settings.py
> GEOSERVER_URL = SITEURL + 'geoserver/'
> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Can you double check what you have in the settings for the
>> geoserver configurations?
>> Sent from Nylas Pro
>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>> the most powerful email app for work
>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>> musumeci.giuseppe at gmail.com> wrote:
>>> Dear Francesco,
>>> I followed the tutorial
>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> </proxyBaseUrl>
>>> and not <proxyBaseUrl>http://localhost:8001/
>>> </proxyBaseUrl>
>>> In this way geoserver seems to work fine.
>>> The problem is I'm not able to upload layers from geonode menu
>>> [Errno 111] Connection refused
>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Giuseppe,
>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>> host. That means
>>> the configuration "config.vm.network
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>>> get the 404 error.
>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>> To be able to upload layers I must set
>>> </proxyBaseUrl>
>>> into usr/share/geoserver/data/global.xml
>>> If I open geoserver from the admin panel the address is
>>> http://localhost:8001/geoserver/web/?1
>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> but If i want for example a layer preview
>>> address change to
>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>> de:fiora_amianto
>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> with error The requested URL /geoserver/geonode/wms was not found on
>>> this server.
>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> config.vm.network
>>> is simply redundant. It has been added to access geoserver out of the
>>> scope of oauth2.
>>> What url are you going to call in the browser for geoserver?
>>> Sent from Nylas Pro
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>> I ran the installation of Geonode using the instructions at the link
>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> I think there are problems in the instructions about geoserver
>>> configuration:
>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>> I changed the default settings with those specified:
>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>> But geoserver don't works: I then set the value to
>>> moreover i Think that to configure vagrantfile as suggested:
>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>> is not correct.
>>> Could someone tell me the correct settings values for geoserver and
>>> vagrantfile?
>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Dear Giuseppe,
>>> as already replied on the italian gfoss list you should check to follow
>>> from scratch the workshop http://geonode.org/ge
>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>> did during foss4g-it. If the error is still happening please let me know as
>>> probably in this case the beta release is also affected and you can help us
>>> with your feedback.
>>> Thanks,
>>> Francesco
>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>> Dear list I'm working with Geonode that I installed on a VM set via
>>> Vagrant When I try to load the shape file, I get this error: *failed to
>>> create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the Apache
>>> error log is as follows: *ERROR: geonode.layers.views: failed to create
>>> /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to google around
>>> I found that in the settings.py file should add the line:
>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>> that the www-data user has all permissions on the www / folder geonode
>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>> that I can't upload. Does anyone know help me?
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/052f6a82/attachment-0001.html>
More information about the geonode-users mailing list
