[GeoNode-users] installing geonode/geoserver docker image in production
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Aug 18 02:29:57 PDT 2017
A question within the question: on you have physical separation of your
services?
I do not see a drawback other than increasing complexity of your setup with
mixed configurations.
Best,
Angelos
On Fri, Aug 18, 2017 at 9:46 AM, Matteo De Stefano <matteo.destefano at nina.no
> wrote:
> Dear GeoNode community,
> I’m installing a 2.6 GeoNode instance in production with multi-tenancy
> (geosites) on Ubuntu server, with gunicorn and nginx. I’m custom installing
> it.
> The Django side is up and running now. For testing, I run it with paver in
> localhost, and everything is ok.
> Now only Geoserver is missing (in production). I was thinking about
> installing Geoserver using the geonode/geoserver docker image, available
> here: [1] I’m learning about docker now.
> My question is:
> Do you think it is a good idea to have GeoNode installed manually for
> production, and just Geoserver (and the data directory) as a docker image?
> Are you aware of any drawback in such approach?
> Thank you,
> Matteo
> [1] https://hub.docker.com/r/geonode/geoserver/
> *________________________________________________________________*
> *Matteo De Stefano*
> Data Scientist and GIS Developer
> *Norwegi**an Institute for Nature Research - NINA*
> Postal address: P.O.Box 5685 Sluppen, NO-7485 Trondheim, NORWAY
> Delivery/Visiting address: Høgskoleringen 9, NO-7034 Trondheim, NORWAY
> • Cell: +47 40645208 <+47%20406%2045%20208> •* www.nina.no
> <http://www.nina.no/>*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170818/c7afcd29/attachment-0001.html>
More information about the geonode-users mailing list
