[GeoNode-users] installing geonode/geoserver docker image in production
Stefan Steiniger sstein at geo.uzh.ch
Mon Aug 21 08:27:56 PDT 2017
just a note: I did in my opinion the mistake to have Postgres/postgis on
a second physical server instead on the same as GeoNode - the first runs
native on server 1 and GeoNode in a VM on server 2. I did this for
available disk space and backup reasons. Although the severs are next to
each other it seems to slow down things (10 MByte/sec connection). So at
least for the next setup I would not separate GeoServer and Postgis. How
a physical separation works for GeoNode and Geoserver, is a good
question (does this even work with django and accessing
html://xxx/geoserver?)
slds,
stefan
On 8/18/17 06:29, Angelos Tzotsos wrote:
> A question within the question: on you have physical separation of
> your services?
> I do not see a drawback other than increasing complexity of your setup
> with mixed configurations.
> Best,
> Angelos
> On Fri, Aug 18, 2017 at 9:46 AM, Matteo De Stefano
> <matteo.destefano at nina.no <mailto:matteo.destefano at nina.no>> wrote:
>     Dear GeoNode community,
>     I’m installing a 2.6 GeoNode instance in production with
>     multi-tenancy (geosites) on Ubuntu server, with gunicorn and
>     nginx. I’m custom installing it.
>     The Django side is up and running now. For testing, I run it with
>     paver in localhost, and everything is ok.
>     Now only Geoserver is missing (in production). I was thinking
>     about installing Geoserver using the geonode/geoserver docker
>     image, available here: [1] I’m learning about docker now.
>     My question is:
>     Do you think it is a good idea to have GeoNode installed manually
>     for production, and just Geoserver (and the data directory) as a
>     docker image? Are you aware of any drawback in such approach?
>     Thank you,
>     Matteo
>     [1] https://hub.docker.com/r/geonode/geoserver/
>     <https://hub.docker.com/r/geonode/geoserver/>
>     *________________________________________________________________*
>     *Matteo De Stefano**
>     *Data Scientist and GIS Developer
>     *Norwegi**an Institute for Nature Research - NINA*
>     Postal address: P.O.Box 5685 Sluppen, NO-7485 Trondheim, NORWAY
>     Delivery/Visiting address: Høgskoleringen 9, NO-7034 Trondheim, NORWAY
>     • Cell: +47 40645208 <tel:+47%20406%2045%20208> •*www.nina.no
>     <http://www.nina.no/>*
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/geonode-users
>     <https://lists.osgeo.org/mailman/listinfo/geonode-users>
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170821/6df11a6e/attachment-0001.html>
More information about the geonode-users mailing list
