[GeoNode-users] installing geonode/geoserver docker image in production
Francesco Bartoli xbartolone at gmail.com
Tue Aug 22 00:14:37 PDT 2017
Hi Stefan,
How  “second physical server” is related with docker images and containers?
Francesco
Il giorno 21/ago/2017, alle ore 17:27, Stefan Steiniger <sstein at geo.uzh.ch> ha scritto:
> just a note: I did in my opinion the mistake to have Postgres/postgis on a second physical server instead on the same as GeoNode - the first runs native on server 1 and GeoNode in a VM on server 2. I did this for available disk space and backup reasons. Although the severs are next to each other it seems to slow down things (10 MByte/sec connection). So at least for the next setup I would not separate GeoServer and Postgis. How a physical separation works for GeoNode and Geoserver, is a good question (does this even work with django and accessing html://xxx/geoserver?)
> slds,
> stefan
> On 8/18/17 06:29, Angelos Tzotsos wrote:
>> A question within the question: on you have physical separation of your services?
>> I do not see a drawback other than increasing complexity of your setup with mixed configurations.
>> Best,
>> Angelos
>> On Fri, Aug 18, 2017 at 9:46 AM, Matteo De Stefano <matteo.destefano at nina.no> wrote:
>> Dear GeoNode community,
>> I’m installing a 2.6 GeoNode instance in production with multi-tenancy (geosites) on Ubuntu server, with gunicorn and nginx. I’m custom installing it.
>> The Django side is up and running now. For testing, I run it with paver in localhost, and everything is ok.
>> Now only Geoserver is missing (in production). I was thinking about installing Geoserver using the geonode/geoserver docker image, available here: [1] I’m learning about docker now.
>> My question is:
>> Do you think it is a good idea to have GeoNode installed manually for production, and just Geoserver (and the data directory) as a docker image? Are you aware of any drawback in such approach?
>> Thank you,
>> Matteo
>> [1] https://hub.docker.com/r/geonode/geoserver/
>> ________________________________________________________________
>> Matteo De Stefano
>> Data Scientist and GIS Developer
>> Norwegian Institute for Nature Research - NINA
>> Postal address: P.O.Box 5685 Sluppen, NO-7485 Trondheim, NORWAY
>> Delivery/Visiting address: Høgskoleringen 9, NO-7034 Trondheim, NORWAY
>> • Cell: +47 40645208 • www.nina.no
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> OSGeo Charter Member
>> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170822/32853768/attachment.html>
More information about the geonode-users mailing list
