[GeoNode-users] geonode loads with IP not with URL/domain name
Simone Dalmasso simone.dalmasso at gmail.com
Sat Aug 19 07:36:10 PDT 2017
Hi, if you change the hostname then you have to run "geonode updateip
XXXXXX", this is because of security checks in django.
Hope this helps
2017-08-19 9:32 GMT-04:00 Mehdi Ahmadi <mehmadi at gmail.com>:
> I have successfully installed geonode on a remote server made some
> customization. Now, it loads with IP address with no problem; however, I
> get the following apache error when I try to load the website using
> URL/host name. Strange enough, geoserver works fine when I try both
> /geoserver and /geoserver. Pinging the host name shows my ip address and my
> nameservers seem to be set appropriately.
> Do you guys have any idea what is the likely reason for this problem?
> Error message:
> Internal Server Error
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator at webmaster at localhost to inform
> them of the time this error occurred, and the actions you performed just
> before this error.
> More information about this error may be available in the server error log.
> Apache/2.4.18 (Ubuntu) Server at ulsdi.ir Port 80
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170819/f00a0267/attachment.html>
More information about the geonode-users mailing list
