[GeoNode-users] Create issue with the shapefiel
Naresh N naresh919 at gmail.com
Mon Aug 28 22:55:33 PDT 2017
Dear Paolo/Simone
Thanks for reply. I have been trying from last couple of days to resolve I
am not able to do. Kindly help me. Few more details about my settings.
I have disable the caching in my geoserver, even though I am facing same
issue.
As I am doing any one of the following  all the features are loading
properly
*(i) Increase and decrease the zoom level (ii) Clicking on Layer Properties
Symbol and Clicked on DISPLAY tab  (iii) Close the layer panel and again
open the layer panel*
*How  and where to write the  code in GeoNode, so that with out manual
intervention an one of the above task should execute.*
Thanks&Regards,
Naresh. N
On Sun, Aug 13, 2017 at 1:51 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> We should determine if it is a GeoServer or GeoNode problem.
> GeoServer should automatically update the GeoWebCache tile cache when
> editing features using a WFS transaction - at least this was working
> properly at GeoNode 2.4. Can you check if the GeoWebCache cache is
> correctly updated for that layer?
> If not, this could be a client cache issue?
> p
> On Fri, Aug 11, 2017 at 8:37 AM, Naresh N <naresh919 at gmail.com> wrote:
> >  Dear All,
> > Please suggest for the following queries
> > 1. Uploaded spatial data(Shapefile). Viewed the uploaded data on Map
> > composer,selected create          option from Edit drop down menu and
> > created new features.
> >   a. Clicked on Layers list and selected same layer/uploaded data and
> used
> > Create Map option,in              map composer few of the newly created
> > features are not loaded. However If I do any one of the        following
> > actions on map composer all the features are visible
> >        (ii) Clicking on Layer Properties Symbol and Clicked on DISPLAY
> tab
> >        (iii) Close the layer panel and again open the layer panel
> >       Please suggest what is the issue? how to resolve above
> >    b.Clicked on  Layers list and selected same layer/uploaded data and
> Layer
> > preview all the features are not visible in all the zoom levels.
> > Thanks&Regards,
> > Naresh.N
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170829/ca809ec7/attachment-0001.html>
More information about the geonode-users mailing list
