[GeoNode-users] Create issue with the shapefiel
Naresh N naresh919 at gmail.com
Tue Aug 29 21:09:52 PDT 2017
Dear Simone,
  Thanks a lot for the response. Sorry for the troubling.
  Even unticking "User Tiled Version"   behaving differently with/without
login.
  Is any help/flow is there how the code executes with and with out login?
If so please kindly share.
  I feel that it is basically not getting full extent of the map viewer to
OpenLayers.Layer. WMS.  I have tried to find  where the WMS layer added
with the given parameters in  GeoExplorer-debug.js, but not able to find.
Please share in which portion of the code Layers are getting added in case
of Layer view, Map view.
Thanks&Regards,
Naresh
On Tue, Aug 29, 2017 at 7:17 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Unfortunately we cannot change geoexplorer. We have another new client but
> still lacks styling tools.
> You could untick the "use tiled version" in the layer display tab in
> geoexplorer.
> Il giorno mar 29 ago 2017 alle 15:34 Naresh N <naresh919 at gmail.com> ha
> scritto:
>> Dear Simone,
>>  Thanks for the response.
>>  Since many of the users uses EDIT/Modify to create/edit new features in
>> uploaded layer. But after editing/creating the features are loading
>> partially only initially and users getting confuse. However if we add same
>> layer as WMS in other portals it is loading fine. Even in layer preview of
>> Geoserver also all the features loading properly.
>>  I think it is issue with Geoexplorer settings .
>>  Kindly look into this issue and please suggest.
>> Thanks&Regards,
>> Naresh
>> On Tue, Aug 29, 2017 at 6:43 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Naresh, not sure what to tell. I the past I also experienced issues with
>>> styles caching in geoserver, without specific errors.
>>> Do not rely on demo as someone changed the default workspace and things
>>> are screwed up.
>>> 2017-08-29 13:17 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone/Paolo,
>>>> This is issue is observed in demo geonode site also . Please login with
>>>> admin account and visit this link http://demo.geonode.org/maps/
>>>> new?layer=hr1:shape_first_1
>>>> Please let me know any other information required to give solution.
>>>> Kindly help me to fix, as it is very important functionality of GeoNode
>>>> Thanks&Regards,
>>>> Naresh
>>>> On Tue, Aug 29, 2017 at 11:25 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear Paolo/Simone
>>>>> Thanks for reply. I have been trying from last couple of days to
>>>>> resolve I am not able to do. Kindly help me. Few more details about my
>>>>> settings.
>>>>> I have disable the caching in my geoserver, even though I am facing
>>>>> same issue.
>>>>> As I am doing any one of the following  all the features are loading
>>>>> properly
>>>>> *(i) Increase and decrease the zoom level (ii) Clicking on Layer
>>>>> Properties Symbol and Clicked on DISPLAY tab  (iii) Close the layer panel
>>>>> and again open the layer panel*
>>>>> *How  and where to write the  code in GeoNode, so that with out manual
>>>>> intervention an one of the above task should execute.*
>>>>> Thanks&Regards,
>>>>> Naresh. N
>>>>> On Sun, Aug 13, 2017 at 1:51 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>>> Hi
>>>>>> We should determine if it is a GeoServer or GeoNode problem.
>>>>>> GeoServer should automatically update the GeoWebCache tile cache when
>>>>>> editing features using a WFS transaction - at least this was working
>>>>>> properly at GeoNode 2.4. Can you check if the GeoWebCache cache is
>>>>>> correctly updated for that layer?
>>>>>> If not, this could be a client cache issue?
>>>>>> p
>>>>>> On Fri, Aug 11, 2017 at 8:37 AM, Naresh N <naresh919 at gmail.com>
>>>>>> wrote:
>>>>>> >  Dear All,
>>>>>> > Please suggest for the following queries
>>>>>> > 1. Uploaded spatial data(Shapefile). Viewed the uploaded data on Map
>>>>>> > composer,selected create          option from Edit drop down menu
>>>>>> and
>>>>>> > created new features.
>>>>>> >   a. Clicked on Layers list and selected same layer/uploaded data
>>>>>> and used
>>>>>> > Create Map option,in              map composer few of the newly
>>>>>> created
>>>>>> > features are not loaded. However If I do any one of the
>>>>>> following
>>>>>> > actions on map composer all the features are visible
>>>>>> >        (ii) Clicking on Layer Properties Symbol and Clicked on
>>>>>> DISPLAY tab
>>>>>> >        (iii) Close the layer panel and again open the layer panel
>>>>>> >       Please suggest what is the issue? how to resolve above
>>>>>> >    b.Clicked on  Layers list and selected same layer/uploaded data
>>>>>> and Layer
>>>>>> > preview all the features are not visible in all the zoom levels.
>>>>>> > Thanks&Regards,
>>>>>> > Naresh.N
>>>>>> > _______________________________________________
>>>>>> > geonode-users mailing list
>>>>>> > geonode-users at lists.osgeo.org
>>>>>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170830/1beb9c70/attachment.html>
More information about the geonode-users mailing list
