[GeoNode-users] Create issue with the shapefiel
Naresh N naresh919 at gmail.com
Thu Aug 31 22:08:20 PDT 2017
Dear Simone,
Thanks a lot for the responses for all of my quires /doubts on Editing issue
I am very happy that,I could able to  understand the issue and as of now I
find the temporary solution.
The issue is whenever the layer is getting edited ,the layer extents are
not getting updated and when this layer is adding to map as WMS, in wms
parameters maxextent property value is adding as old extent of the layers.
Because of this few tiles are not loading and few tiles are partially
loading.
The following is may not be efficient solution, however to overcome I have
did the changes in following line in GeoExplorer-debug.js
 In  createLayerRecord function (approxmiately line no: 75478) and
commented the following lines
               maxExtent: maxExtent, (75499)
               restrictedExtent: maxExtent,(75450).
As above is temporary solution, kindly help me in the following to have
correct solution.
 1. After editing the features, how to update the layer extents from the
code
 2. Is layer extents are stored in database table? if so please let me know
the table name
 3. Not able to understand, from which line of the code extent is getting
from the layer?
Best Regards,
Naresh
On Wed, Aug 30, 2017 at 9:39 AM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Simone,
>   Thanks a lot for the response. Sorry for the troubling.
>   Even unticking "User Tiled Version"   behaving differently with/without
> login.
>   Is any help/flow is there how the code executes with and with out login?
> If so please kindly share.
>   I feel that it is basically not getting full extent of the map viewer to
> OpenLayers.Layer. WMS.  I have tried to find  where the WMS layer added
> with the given parameters in  GeoExplorer-debug.js, but not able to find.
> Please share in which portion of the code Layers are getting added in case
> of Layer view, Map view.
> Thanks&Regards,
> Naresh
> On Tue, Aug 29, 2017 at 7:17 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Unfortunately we cannot change geoexplorer. We have another new client
>> but still lacks styling tools.
>> You could untick the "use tiled version" in the layer display tab in
>> geoexplorer.
>> Il giorno mar 29 ago 2017 alle 15:34 Naresh N <naresh919 at gmail.com> ha
>> scritto:
>>> Dear Simone,
>>>  Thanks for the response.
>>>  Since many of the users uses EDIT/Modify to create/edit new features in
>>> uploaded layer. But after editing/creating the features are loading
>>> partially only initially and users getting confuse. However if we add same
>>> layer as WMS in other portals it is loading fine. Even in layer preview of
>>> Geoserver also all the features loading properly.
>>>  I think it is issue with Geoexplorer settings .
>>>  Kindly look into this issue and please suggest.
>>> Thanks&Regards,
>>> Naresh
>>> On Tue, Aug 29, 2017 at 6:43 PM, Simone Dalmasso <
>>>> Naresh, not sure what to tell. I the past I also experienced issues
>>>> with styles caching in geoserver, without specific errors.
>>>> Do not rely on demo as someone changed the default workspace and things
>>>> are screwed up.
>>>> 2017-08-29 13:17 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone/Paolo,
>>>>> This is issue is observed in demo geonode site also . Please login
>>>>> with admin account and visit this link http://demo.geonode.org/maps/n
>>>>> ew?layer=hr1:shape_first_1
>>>>> Please let me know any other information required to give solution.
>>>>> Kindly help me to fix, as it is very important functionality of GeoNode
>>>>> Thanks&Regards,
>>>>> Naresh
>>>>> On Tue, Aug 29, 2017 at 11:25 AM, Naresh N <naresh919 at gmail.com>
>>>>> wrote:
>>>>>> Dear Paolo/Simone
>>>>>> Thanks for reply. I have been trying from last couple of days to
>>>>>> resolve I am not able to do. Kindly help me. Few more details about my
>>>>>> settings.
>>>>>> I have disable the caching in my geoserver, even though I am facing
>>>>>> same issue.
>>>>>> As I am doing any one of the following  all the features are loading
>>>>>> properly
>>>>>> *(i) Increase and decrease the zoom level (ii) Clicking on Layer
>>>>>> Properties Symbol and Clicked on DISPLAY tab  (iii) Close the layer panel
>>>>>> and again open the layer panel*
>>>>>> *How  and where to write the  code in GeoNode, so that with out
>>>>>> manual intervention an one of the above task should execute.*
>>>>>> Thanks&Regards,
>>>>>> Naresh. N
>>>>>> On Sun, Aug 13, 2017 at 1:51 AM, Paolo Corti <pcorti at gmail.com>
>>>>>> wrote:
>>>>>>> Hi
>>>>>>> We should determine if it is a GeoServer or GeoNode problem.
>>>>>>> GeoServer should automatically update the GeoWebCache tile cache when
>>>>>>> editing features using a WFS transaction - at least this was working
>>>>>>> properly at GeoNode 2.4. Can you check if the GeoWebCache cache is
>>>>>>> correctly updated for that layer?
>>>>>>> If not, this could be a client cache issue?
>>>>>>> p
>>>>>>> On Fri, Aug 11, 2017 at 8:37 AM, Naresh N <naresh919 at gmail.com>
>>>>>>> wrote:
>>>>>>> >  Dear All,
>>>>>>> > Please suggest for the following queries
>>>>>>> > 1. Uploaded spatial data(Shapefile). Viewed the uploaded data on
>>>>>>> Map
>>>>>>> > composer,selected create          option from Edit drop down menu
>>>>>>> and
>>>>>>> > created new features.
>>>>>>> >   a. Clicked on Layers list and selected same layer/uploaded data
>>>>>>> and used
>>>>>>> > Create Map option,in              map composer few of the newly
>>>>>>> created
>>>>>>> > features are not loaded. However If I do any one of the
>>>>>>> following
>>>>>>> > actions on map composer all the features are visible
>>>>>>> >        (ii) Clicking on Layer Properties Symbol and Clicked on
>>>>>>> DISPLAY tab
>>>>>>> >        (iii) Close the layer panel and again open the layer panel
>>>>>>> >       Please suggest what is the issue? how to resolve above
>>>>>>> >    b.Clicked on  Layers list and selected same layer/uploaded data
>>>>>>> and Layer
>>>>>>> > preview all the features are not visible in all the zoom levels.
>>>>>>> > Thanks&Regards,
>>>>>>> > Naresh.N
>>>>>>> > _______________________________________________
>>>>>>> > geonode-users mailing list
>>>>>>> > geonode-users at lists.osgeo.org
>>>>>>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> Paolo Corti
>>>>>>> Geospatial software developer
>>>>>>> web: http://www.paolocorti.net
>>>>>>> twitter: @capooti
>>>>>>> skype: capooti
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170901/1239b912/attachment.html>
More information about the geonode-users mailing list
