[GeoNode-users] Data Issue When assessing GeoNode IP address
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jul 10 22:45:55 PDT 2017
Hi, this looks like a misconfiguration, in particular I see two issues:
- the web server is not correctly configured to serve the thumbnails or the
thumbnails are not generated correctly
- the permissions issue is probably due to the fact that geoserver cannot
reach GeoNode to ask for authorization (and this could also be the reason
of the issue 1)
Check the geoserver's logs to see if there are auth issues and in case fix
the geoserver configuration
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#setup-geoserver
2017-07-10 9:17 GMT+02:00 Nizam ud Din <nizam_space at hotmail.com>:
> Dear All
> I am new one in using GeoNode.
> I installed GeoNode 2.4 on Window and working well.
> I am accessing on other systems (computer) via IP address,I have the
> following issues;
> 1-layers/documents not showing in the data content window as below;
> 2- when I want to download data i received "Error! permission to download
> the resource could not be requested to resource owner because of an error".
> Best Regards
> * Nizam-ud-Din*
> *Sr. Manager GIS **The Urban Unit*
> (Urban Sector Planning & Management Services Unit (Private) Limited)
> * Government of The Punjab,*
> * 503-**Shaheen Complex
> <https://maps.google.com/maps?q=31.562863%2c+74.332847&num=1&t=h&vpsrc=6&ie=UTF8&ll=31.562749%2c74.33297&spn=0.001296%2c0.002642&z=19&iwloc=A>
> , **5th Floor, ** Egerton Road, Lahore. Pakista*n
> *------------------------------------ *Mob: +92-321-4243824
> <+92%20321%204243824>
> Office: +92-042-99205316 <+92%2042%2099205316>-22,042-36376365
> fax: 042-99205323
> Email: nizam at urbanunit.gov.pk, nizam_space at hotmail.com
> *http://www.urbanunit.gov.pk <http://www.urbanunit.gov.pk/>*
> http://www.irispunjab.gov.pk
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/1fbc3be8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/1fbc3be8/attachment-0001.png>
More information about the geonode-users mailing list
