[GeoNode-users] ACTIVITY Feed - Option
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 11 05:46:31 PDT 2017
You have to comment out the activity button in the template of profile
detail too
https://github.com/GeoNode/geonode/blob/master/geonode/people/templates/people/profile_detail.html#L130
2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
> Thanks for quick response
>  I have commented the line 86 i.e. (r'^activity/',
> include('actstream.urls')), then we are not able to see peoples profile
> list. I want only activity feed should not be visible/accessible to the
> users. Please suggest
> Best Regards,
> Naresh
> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, you could exclude the activity urls by commenting this line
>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear All,
>>>  Please any body can share how to disable activity stream option for all
>>> the users.
>>> With Best Regards,
>>> Naresh
>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear Fabiani,
>>>>  Thanks for sharing the links, I will go through the links
>>>> Best Regards,
>>>> Naresh
>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> Hi,
>>>>> recently I have rebuilt almost from scratch the source code of
>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>> You can find the GeoNode module here
>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>> It actually depends on this one
>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>> geoexplorer
>>>>> which, again, references other git submodules.
>>>>> See instructions here
>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>>> also you need to download sources by uasing
>>>>> git submodule sync
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A
>>>>> 55054  Massarosa (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>> The information in this message and/or attachments, is intended solely
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>>> strictly forbidden except previous formal approval of the named
>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>> information in this message that has been received in error. The sender
>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>> made after they were sent or for other risks which arise as a result of
>>>>> e-mail transmission, viruses, etc.
>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>> Geoexplorer is quite difficult to modify, and I don't know where you
>>>>>> could do such change.
>>>>>> Here's a very minimal documentation on how to make geoexplorer work
>>>>>> in dev mode but then not sure how you can compile it back and deploy
>>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>  Yes as told functionality is working properly based on permissions
>>>>>>> as geoserver handling the styling option. But if user is not having
>>>>>>> permission if he does the style change,after that showing error message
>>>>>>> like as follows, user time will waste it is better if we disable based on
>>>>>>> previliges. How Edit option is implemented, kindly tell us where i need to
>>>>>>> modify the functionality
>>>>>>>     [image: Inline image 1]
>>>>>>> Thanks&Regards,
>>>>>>> Naresh
>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>> anyway,
>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone and all,
>>>>>>>>>   One more query, please help me to do
>>>>>>>>>  If user has option for visualizing the layer and not having style
>>>>>>>>> option, then also Style icon is enabled mode in Map and Layer Window of
>>>>>>>>> GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>> having permission for add/edit style
>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>>> styling the data
>>>>>>>>> Best Regards,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>>> Best Regards,
>>>>>>>>>> Naresh
>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This is
>>>>>>>>>>> the app geonode is using to implement the activity stream.
>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>    Is it possible Activity Feed of the People  should be
>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/b3258a31/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/b3258a31/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/b3258a31/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/b3258a31/attachment-0005.png>
More information about the geonode-users mailing list
