[GeoNode-users] ACTIVITY Feed - Option
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 12 00:23:50 PDT 2017
Sorry. Commenting the line in the HTML is not enough. You have to remove
it.
Il giorno mer 12 lug 2017 alle 08:18 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear Simone,
>   Thanks for the response. After commenting following two lines, it did
> not working as per expected.
> https://github.com/GeoNode/geonode/blob/master/geonode/people/templates/people/profile_detail.html#L130 and
>   https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
> In this case also Not able to see the user list,please find the below
> screenshot for reference
> [image: Inline image 1]
> Please find below my requirement, I want on click of People, the user list
> should be available as follows and there should not be no option to see the
> activity feed of the user.
> [image: Inline image 2]
>   Even if user know direct url of the activity feed, he should not able
> to see the activity feed, I mean with the url
> http://192.168.197.108/activity/actors/31/5/  now I am able to see the
> activity feed. So even with direct url user should not see activity feed
> Please help me to do the task.
> Best Regards,
> Naresh. N
> On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> You have to comment out the activity button in the template of profile
>> detail too
>> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>> Thanks for quick response
>>>  I have commented the line 86 i.e. (r'^activity/',
>>> include('actstream.urls')), then we are not able to see peoples profile
>>> list. I want only activity feed should not be visible/accessible to the
>>> users. Please suggest
>>> Best Regards,
>>> Naresh
>>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>>>> Hi, you could exclude the activity urls by commenting this line
>>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear All,
>>>>>  Please any body can share how to disable activity stream option for
>>>>> all the users.
>>>>> With Best Regards,
>>>>> Naresh
>>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>>>> Dear Fabiani,
>>>>>>  Thanks for sharing the links, I will go through the links
>>>>>> Best Regards,
>>>>>> Naresh
>>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>> Hi,
>>>>>>> recently I have rebuilt almost from scratch the source code of
>>>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>>>> You can find the GeoNode module here
>>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>>> It actually depends on this one
>>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-geoexplorer
>>>>>>> which, again, references other git submodules.
>>>>>>> See instructions here
>>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>>>>> also you need to download sources by uasing
>>>>>>> git submodule sync
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A
>>>>>>> 55054  Massarosa (LU)
>>>>>>> Italy
>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>> The information in this message and/or attachments, is intended
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>> information in this message that has been received in error. The sender
>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>> e-mail transmission, viruses, etc.
>>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>>> Geoexplorer is quite difficult to modify, and I don't know where
>>>>>>>> you could do such change.
>>>>>>>> Here's a very minimal documentation on how to make geoexplorer work
>>>>>>>> in dev mode but then not sure how you can compile it back and deploy
>>>>>>>> http://docs.geonode.org/en/master/tutorials/devel/devel_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>  Yes as told functionality is working properly based on
>>>>>>>>> permissions as geoserver handling the styling option. But if user is not
>>>>>>>>> having permission if he does the style change,after that showing error
>>>>>>>>> message like as follows, user time will waste it is better if we disable
>>>>>>>>> based on previliges. How Edit option is implemented, kindly tell us where i
>>>>>>>>> need to modify the functionality
>>>>>>>>> Thanks&Regards,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>>>> anyway,
>>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>>   One more query, please help me to do
>>>>>>>>>>>  If user has option for visualizing the layer and not having
>>>>>>>>>>> style option, then also Style icon is enabled mode in Map and Layer Window
>>>>>>>>>>> of GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>>>> having permission for add/edit style
>>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>>>>> styling the data
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This is
>>>>>>>>>>>>> the app geonode is using to implement the activity stream.
>>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>    Is it possible Activity Feed of the People  should be
>>>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/4f6c49fe/attachment-0009.png>
More information about the geonode-users mailing list
