[GeoNode-users] Installation Problems with version 2.6 on Ubuntu 16.04
Cliff Patterson cliffpatterson at gmail.com
Thu Jun 8 09:22:40 PDT 2017
PS: and I am unable to authenticate via the geonode website.
On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <cliffpatterson at gmail.com>
wrote:
> Hello,
> I decided to give Geonode 2.6 a go and installed it on a fresh VM running
> Ubuntu 16.04.2 x64. I installed it with the following commands:
> sudo add-apt-repository ppa:geonode/stable
> sudo apt-get update
> sudo apt-get install geonode
> geonode createsuperuser
> sudo geonode-updateip 67.207.87.119
> When creating the super user, I get the following warning:
> System check identified some issues:
> WARNINGS:
> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in Django
> 1.8 and the TEMPLATES dictionary takes precedence. You must put the values
> of the following settings into your default TEMPLATES dict: TEMPLATE_DIRS.
> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> ManyToManyField.
> Username: test
> Email address:
> Password:
> Password (again):
> Superuser created successfully.
> When running sudo geonode-updateip 67.207.87.119, the following happens:
> 1) Hangs on "Inspecting the available layers in GeoServer ..."
> 2) Geonode does get up and running at 67.207.87.119 but no ability to login
> Replacing SITEURL value with '67.207.87.119' in
> /etc/geonode/local_settings.py ... done.
> Adding entry for '67.207.87.119' in /usr/share/geoserver/data/printing/config.yaml
> ... done.
> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ... done.
> Setting up oauth
> Am I missing something in the instructions? Do we need to install
> Geoserver on Tomcat7 first, then Geonode? As far as I can see, Geoserver
> has not been installed, which I thought was part of the geonode
> installation, but I could be wrong.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170608/398faef9/attachment-0001.html>
More information about the geonode-users mailing list
