[GeoNode-users] Layer Editing Error
Naresh N naresh919 at gmail.com
Fri Jun 9 01:51:56 PDT 2017
Dear Bartoli,Simone,
 Thanks for the helping. Downloaded Geosever2.7.4 war from Geoserver
official site and replaced  with Geoserver2.11.1, the layer editing
functionality is worked. Now i understand that basically issue is with
Geoserver version . Now I am checking all other functionalities, hoping  I
will not get any unexpected error/behaviour.
Thanks again........
Thanks,
Naresh
On Fri, Jun 9, 2017 at 1:12 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Naresh,
> the same command suggested by Simone should download the correct GeoServer
> version which relies on the old authentication system.
> Francesco
> Il giorno 09/giu/2017, alle ore 09:39, Naresh N <naresh919 at gmail.com> ha
> scritto:
> Dear Simone,
> I have deployed GeoNode 2.4 version. I think there is no concept of oauth
> in GeoNode 2.4 version.I am facing the issue with GeoNode 2.4. Please
> suggest how to overcome the issue in GeoNode2.4 version
> Thanks,
> Naresh
> On Fri, Jun 9, 2017 at 12:57 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Running "paver setup" in your geonode virtualenv will download it into
>> the "downloaded folder" Then you will have to configure the oauth2
>> mechanism http://docs.geonode.org/en/master/tutorials/admin/
>> geoserver_geonode_security/index.html#geonode-and-geoserver-
>> a-a-interaction
>> 2017-06-09 9:19 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>  Thanks for the response.
>>>  But I have configured GeoNode2.4 in my RHEL machine. In downloaded
>>> GeoNode Zip Geoserver.war file is not available. How to get shipped
>>> geoserver.war file in case of GeoNode deployment in Linux.
>>> Thanks,
>>> Naresh
>>> On Fri, Jun 9, 2017 at 12:44 PM, Simone Dalmasso <
>>>> Hi,
>>>> GeoNode requires it's own Geoserver. It is shipped with it and is
>>>> version 2.9. Security and permissions won't work otherwise.
>>>> 2017-06-09 8:58 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear ALL,
>>>>> When I am editing the layer it is showing following error. Please
>>>>> suggest to fix
>>>>> <ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema"
>>>>> xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2
>>>>> 001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www
>>>>> .opengis.net/ows http://192.168.198.209/geoserv
>>>>> er/schemas/ows/1.0.0/owsExceptionReport.xsd">
>>>>>   <ows:Exception exceptionCode="NoApplicableCode">
>>>>>     <ows:ExceptionText>{http://192.168.198.209/geoserver/cite}_6
>>>>> _9_2017_9657073 is read-only</ows:ExceptionText>
>>>>>   </ows:Exception>
>>>>> </ows:ExceptionReport>
>>>>> System Details : Geo Node is configured in RHEL7.2 64 bit machine
>>>>>                          Geoserver version 2.11.1
>>>>>                             jre version is 1.8
>>>>> * Note:  If login the geoserver with admin credential in another tab
>>>>> and layer editing functionality is working*
>>>>> *Please kindly suggest any layer security settings need to update in
>>>>> Geoserver2.11.1*
>>>>> *Thanks,*
>>>>> *Naresh*
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/3324d682/attachment.html>
More information about the geonode-users mailing list
