[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jun 15 00:47:38 PDT 2017
You can try with http://demo.geonode.org/geoserver/wms. Not sure about our
other question, don't think is possible in the standard code.
2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>   Thanks for the replies. Is any other External WMS Layer url is available
> ,please share me to test.  Is that any mechanism is available in case if
> WFS of Geoserver is disabled,not enabling EDIT option while reading error
> code.
> Thanks,
> Naresh
> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Ah I see, then is not your or geonode fault. This is an issue of that
>> geoserver.
>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>> Geoserver of others and I am adding thishttp://bhuvan5.nrsc.gov.in
>>> /bhuvan/web/ url to GeoNode using Layers ->Add server option. It is
>>> adding but it shows the issue which I mentioned in my earlier mail.
>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>> demo GeoNode site  and  can be observed same issue.
>>> Thanks,
>>> Naresh
>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>   Earlier I faced layer issue and with your guidance i  have fixed the
>>>>> issue. Please find the link our earlier converstaion
>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td5323603.html
>>>>>  which contains the steps I followed to install.
>>>>>  I have verified my geoserver instance  and version is 2.7.4. Not able
>>>>> to understand from where you  observed my Geoserver version is 2.0.2?.
>>>>>  Please let me know any other information required to solve the issue
>>>>> Thanks,
>>>>> Naresh
>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x. Could
>>>>>> you clarify how you installed it?
>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>> _geoserver_application.html  to configure Geoserver with GeoNode
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear simone,
>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Dear Simone,
>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I
>>>>>>>>>> have tested with the url http://bhuvan5.nrsc.gov.in/bhuvan/wms
>>>>>>>>>> , I am getting same issue. Please help me to resolve
>>>>>>>>>> My System details:
>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>> Hi seems that you are missing a configuration in geoserver. How
>>>>>>>>>>> did you install geonode?
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>> Please also find the attached screenshot with this mail. The
>>>>>>>>>>>> WMS url  added  is http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/2e7a8b4f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/2e7a8b4f/attachment-0001.png>
More information about the geonode-users mailing list
