[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Fri Jun 16 05:46:43 PDT 2017
Dear Simone,
Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209') and in
proxy/views.py linenumber: 37 is reverted means removed ip adress and kept
as hostname. It is showing following error
[Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal Server
Error: /proxy/
[Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback (most
recent call last):
[Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
"/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line 112,
in get_response
[Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
wrapped_callback(request, *callback_args, **callback_kwargs)
[Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
"/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
[Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
PROXY_ALLOWED_HOSTS +=hostname
[Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError: cannot
concatenate 'str' and 'tuple' objects
[Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal Server
Error: /proxy/
[Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback (most
recent call last):
[Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
in get_response
[Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
[Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
[Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
[Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError: cannot
concatenate 'str' and 'tuple' objects*
[Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622] Misconfiguration of
certificate's CN and virtual name. The certificate CN has
localhost4.localdomain4. We expected localhost.localdomain as virtual name.
[Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library Error:
-12263 SSL received a record that exceeded the maximum permissible length
if in proxy/views.py if i add in place of hostname ip adress of the
GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
objects ' *will go, how ever the error which I mentioned in my earlier mail
retains.
Please suggest how to overcome above error '*TypeError: cannot concatenate
'str' and 'tuple' objects ' *with out editing proxy/views.py
And also kindly suggest me how to correct misconfiguration of SSL error,
since I am not using https any where
Thanks,
Naresh
On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Not a good idea to modify the python files, You can add the
> PROXY_ALLOWED_HOSTS in settings.
> Anyway, seems you are running under ssl. Seems a misconfiguration of it.
> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>  I have tried with the url provided http://demo.genode.org/geoserver/wms,
>> getting the following error.
>> [image: Inline image 1]
>> *Please find the apaahe error log file and attached views.py file from
>> proxy folder of geonode for the reference. In view.py in line no: 37 is
>> modified (commented host name and placed IP adrdress of GeoNode installed
>> system)*
>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal Server
>> Error: /proxy/
>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback (most
>> recent call last):
>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>> 112, in get_response
>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response =
>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>> conn.request(request.method, locator, request.body, headers)
>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>> self._send_request(method, url, body, headers)
>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>> self.endheaders(body)
>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>> self._send_output(message_body)
>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]     self.send(msg)
>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]     self.connect()
>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]     self.timeout,
>> self.source_address)
>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno 111]
>> Connection refused
>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal Server
>> Error: /proxy/
>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback (most
>> recent call last):
>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response =
>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]     self.send(msg)
>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]     self.connect()
>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]     self.timeout,
>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno 111]
>> Connection refused
>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208] Misconfiguration
>> of certificate's CN and virtual name. The certificate CN has
>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library Error:
>> Please kindly suggest me, do i need to modify some where else?
>> Thanks,
>> Naresh
>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Simone,
>>>   Thanks. I will try with the provided url.
>>> Thanks,
>>> Naresh
>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure about
>>>> our other question, don't think is possible in the standard code.
>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>> error code.
>>>>> Thanks,
>>>>> Naresh
>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>> Ah I see, then is not your or geonode fault. This is an issue of that
>>>>>> geoserver.
>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>>> Geoserver of others and I am adding thishttp://bhuvan5.nrsc.gov.in
>>>>>>> /bhuvan/web/ url to GeoNode using Layers ->Add server option. It is
>>>>>>> adding but it shows the issue which I mentioned in my earlier mail.
>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>>>>>> demo GeoNode site  and  can be observed same issue.
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have fixed
>>>>>>>>> the issue. Please find the link our earlier converstaion
>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4. Not
>>>>>>>>> able to understand from where you  observed my Geoserver version is 2.0.2?.
>>>>>>>>>  Please let me know any other information required to solve the
>>>>>>>>> issue
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x.
>>>>>>>>>> Could you clarify how you installed it?
>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>>>>>> _geoserver_application.html  to configure Geoserver with GeoNode
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I
>>>>>>>>>>>>>> have tested with the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>> /bhuvan/wms   , I am getting same issue. Please help me to
>>>>>>>>>>>>>> resolve
>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in geoserver.
>>>>>>>>>>>>>>> How did you install geonode?
>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>> Please also find the attached screenshot with this mail.
>>>>>>>>>>>>>>>> The WMS url  added  is http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>> van/wms.
>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/05f59159/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/05f59159/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/05f59159/attachment-0003.png>
More information about the geonode-users mailing list
