[GeoNode-users] Geosites
Simone Dalmasso simone.dalmasso at gmail.com
Wed Mar 1 01:02:20 PST 2017
This is strange, are you accessing geonode on localhost right. Could there
be anything preventing connections on localhost inside the machine?
2017-03-01 9:51 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
> Hello Simone
> Apparently I have done so but it seems its not picking up. This is what I
> have in my config.xml
> <baseUrl>http://localhost</baseUrl>
> Also am running the geosites on my local machine as at now.
> Kind regards
> Gideon Yegon
> Phone: +254 713 280 960
> http://www.linkedin.com/in/gyegon
> <http://www.linkedin.com/in/gideon-yegon-956162ab>
> skype: g.yegon
> On Wed, Mar 1, 2017 at 11:40 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi,
>> you can update the geoserver_data_dir/security/au
>> th/GeonodeAuthProvider/config.xml with the correct url of GeoNode, and
>> then restart Tomcat.
>> Hope this helps
>> 2017-02-28 14:12 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>> Hello all,
>>> I am having broken thumbnails
>>> and legends of layers on geonode. And it seems the issue is the
>>> communication between geonode and geoserver. I have tried updating the
>>> web.xml file and baseUrl but no lack.
>>> Does anyone know how to solve this problem. Thanks in advance.
>>> Below is the error am getting from geoserver logs.
>>> 2017-02-28 10:53:58,155 WARN [geonode.security] - Error connecting to
>>> the GeoNode server for authentication purposes
>>> org.springframework.security.authentication.AuthenticationServiceException:
>>> Communication with GeoNode failed (GeoNodeSessionAuthToken)
>>>         at org.geonode.security.GeoNodeAuthenticationProvider.authentic
>>> ate(GeoNodeAuthenticationProvider.java:68)
>>>         at org.geoserver.security.GeoServerAuthenticationProvider.authe
>>> nticate(GeoServerAuthenticationProvider.java:58)
>>>         at org.springframework.security.authentication.ProviderManager.
>>> authenticate(ProviderManager.java:156)
>>>         at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(
>>> GeoNodeCookieProcessingFilter.java:98)
>>>         at org.springframework.security.web.FilterChainProxy$VirtualFil
>>> terChain.doFilter(FilterChainProxy.java:323)
>>>         at org.geoserver.security.filter.GeoServerCompositeFilter$Neste
>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>         at org.springframework.security.web.context.SecurityContextPers
>>> istenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>         at org.geoserver.security.filter.GeoServerSecurityContextPersis
>>> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFi
>>> lter.java:53)
>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>         at org.geoserver.security.filter.GeoServerCompositeFilter.doFil
>>> ter(GeoServerCompositeFilter.java:92)
>>>         at org.springframework.security.web.FilterChainProxy.doFilter(F
>>> ilterChainProxy.java:173)
>>>         at org.geoserver.security.GeoServerSecurityFilterChainProxy.doF
>>> ilter(GeoServerSecurityFilterChainProxy.java:135)
>>>         at org.springframework.web.filter.DelegatingFilterProxy.invokeD
>>> elegate(DelegatingFilterProxy.java:346)
>>>         at org.springframework.web.filter.DelegatingFilterProxy.doFilte
>>> r(DelegatingFilterProxy.java:259)
>>>         at org.apache.catalina.core.ApplicationFilterChain.internalDoFi
>>> lter(ApplicationFilterChain.java:241)
>>>         at org.apache.catalina.core.ApplicationFilterChain.doFilter(App
>>> licationFilterChain.java:208)
>>>         at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.j
>>> ava:87)
>>>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>         at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDeb
>>> ugFilter.java:48)
>>>         at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilt
>>> er.java:44)
>>> Kind regards
>>> Gideon Yegon
>>> skype: g.yegon
>>> On Tue, Feb 28, 2017 at 11:12 AM, Simone Dalmasso <
>>>> What version of GeoNode did you install?
>>>> Seems that Geoserver cannot find geonode but depending on the version,
>>>> the configuration may be different.
>>>> 2017-02-28 9:08 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>>> Hello Simone
>>>>> Am seeing two errors;
>>>>> 2017-02-28 09:36:37,190 INFO [geoserver.wms] -
>>>>> Request: getServiceInfo
>>>>> 2017-02-28 09:36:37,191 ERROR [geoserver.ows] -
>>>>> org.geoserver.platform.ServiceException: Could not find layer
>>>>> geonode:kewasco_connections
>>>>> 2017-02-28 09:36:37,205 WARN [geonode.security] - Error connecting to
>>>>> However i can be redirected automatically from geonode to geoserver
>>>>> and also be able to preview layers in my geoserver. I think am missing
>>>>> something out. Kindly assist thank you.
>>>>> Kind regards
>>>>> Gideon Yegon
>>>>> skype: g.yegon
>>>>> On Tue, Feb 28, 2017 at 10:44 AM, GIDEON YEGON <gyegon2001 at gmail.com>
>>>>> wrote:
>>>>>> Hello Simon,
>>>>>> Thanks for your prompt response, but the redirection from geonode to
>>>>>> geoserver is working fine, am able to connect automatically.
>>>>>> Or there could be other problems causing geonode and geoserver not
>>>>>> communicating well? Sorry for not being smart enough!
>>>>>> Kind regards
>>>>>> Gideon Yegon
>>>>>> skype: g.yegon
>>>>>> On Tue, Feb 28, 2017 at 10:18 AM, Simone Dalmasso <
>>>>>>> Hi, could be that geonode and geoserver don't connect properly.
>>>>>>> Check the geoserver logs.
>>>>>>> 2017-02-28 7:57 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>>>>>> Hello all,
>>>>>>>> I wanted to know what could be wrong as i was able to successfully
>>>>>>>> install geosites on my local machine. But am getting broken thumbnails and
>>>>>>>> legend for the layers.
>>>>>>>> Kindly assist. Thanks.
>>>>>>>> Kind regards
>>>>>>>> Gideon Yegon
>>>>>>>> skype: g.yegon
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170301/317d9a4e/attachment-0001.html>
More information about the geonode-users mailing list
