[GeoNode-users] Javascript+html
Simone Dalmasso simone.dalmasso at gmail.com
Tue Mar 7 23:25:28 PST 2017
ok, I strongly suggest you to go over the geonode docs and follow the
tutorials there. You need to understand what the components do and how to
work with geonode.
http://docs.geonode.org/en/master/
2017-03-08 8:19 GMT+01:00 Yogini Sonawane <yogini.sonawane92 at gmail.com>:
> Okay Sir,
>        1) My aim is to run  my coding on GeoNode. I want to make an
> application using GeoNode. I thought that.. after storing and publishing
> the .html file on Geoserver it will show on GeoNode too, like I done with
> spatial data (.shp, .prj, .shx, .dbf )
> I have this .doc file. In that I made a coding using open layers, html,
> css and javascript. It is an application to digitize geographical features
> using line, point and polygon. I want to apply it on GeoNode thats why i
> made it in .html format.
>            How the code is running in .html file.. i wish to create same
> application which will run on Geonode.. .On the openLayer I can digitize
> the area or I can show the pop up etc.
>        2)  Where can i do coding to make an application which will run in
> GeoNode ? If i did some coding with python or some another language, How
> can i apply it on GeoNode?
>        3)I have school data in .excel format.. with address, lat long and
> facilities. i want to store it in database like PostGIS/ Postgree . Then a
> coding which should apply in Geonode and then want to make an application
> using CartoView.
> On Wed, Mar 8, 2017 at 12:04 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, I don't understand what you want to achieve. It is not possible to
>> load an html file in geoserver. Geoserver can only publish spatial data,
>> and this is done through geonode.
>> 2017-03-08 7:33 GMT+01:00 Yogini Sonawane <yogini.sonawane92 at gmail.com>:
>>> ---------- Forwarded message ----------
>>> From: Yogini Jalidar Sonawane <yoginij.sonawane at st.niituniversity.in>
>>> Date: Wed, Mar 8, 2017 at 12:00 PM
>>> Subject: Fwd: Javascript+html
>>> To: Yogini Sonawane <yogini.sonawane92 at gmail.com>
>>> Date: Thu, Mar 2, 2017 at 11:43 AM
>>> Subject: Re: Javascript+html
>>> To: jitendra shah <jituviju at gmail.com>
>>> To save .html file in user/share/geoserver/data... I dont have the www
>>> named file in user/share/geoserver/data in Geosever , where i can publish
>>> my .html file on Geoserver
>>> On Thu, Mar 2, 2017 at 11:12 AM, Yogini Jalidar Sonawane <
>>> yoginij.sonawane at st.niituniversity.in> wrote:
>>>> Sir,
>>>> I want to run .html file on GeoNode. How can it possible ?
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170308/d3a42b3d/attachment.html>
More information about the geonode-users mailing list
