[GeoNode-users] Connection error
Francesco Bartoli xbartolone at gmail.com
Wed Mar 22 09:35:27 PDT 2017
Hi Carmine,
what do you mean with upload a spatialite layer in geoserver? Maybe using its extension for spatialite? Can you explain a little better your workflow?
Il giorno 22/mar/2017, alle ore 17:17, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it> ha scritto:
> thanks,
> but sometimes we need to edit a spatialite layer from different qgis desktop in remote connection to geonode postgresdb. Is it possible without receive that error?
> many thanks
> carmine
> Il 03/22/2017 02:50 PM, Simone Dalmasso ha scritto:
>> Hi you should use Geonode to load data. Or run the updatelayers commands after you loaded in geoserver.
>> Il giorno mer 22 mar 2017 alle 14:00 Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it> ha scritto:
>> Dear,
>> if I upload a layer (shapefile or spatialite) directly in geoserver and then I create a map using local geoserver option to add a layer, I receive this error:
>> Connection Error
>> The server returned an error: 404 NOT FOUND.
>> If I click on Detail I can only see Page not Found.
>> I use geonode version 2.4 on Ubuntu 14.04.
>> How could I solve this issue?
>> thank in advance
>> carmine
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170322/ba1d9d9c/attachment.html>
More information about the geonode-users mailing list
