[GeoNode-users] Admin auto login with geoserver not working
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Mon May 8 01:24:48 PDT 2017
Hey Simone,
great to hear thanks a lot for clarification!
cheers,
toni
> Am 08.05.2017 um 09:25 schrieb Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Toni,
> GeoNode and Geoserver now authenticate and authorise via oauth2, you will find a handy button in geoserver (with the geonode logo) to authenticate easily.
> 2017-05-08 8:05 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>>:
> Francesco,
> thanks a lot for your reply. From you answer I assume that this point
> All we need to do now is to integrate GeoNode authentication so that GeoNode administrator will be able to access and administer GeoServer as well.
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration>
> has changed in 2.6. Can you say why? For me this was a handy feature as one
> does not have to remember geoserver login credentials (which can be different
> from geonode.)
> thanks and a good start to the week,
> toni
>> Am 07.05.2017 um 23:58 schrieb Francesco Bartoli <xbartolone at gmail.com <mailto:xbartolone at gmail.com>>:
>> Hi Toni,
>> this behavior is expected, the first time you access geoserver from geonode you have to login with the button on top of the page.
>> Francesco
>> Il giorno 07/mag/2017, alle ore 20:38, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> ha scritto:
>>> Hi,
>>> this might be easy. On a Ubuntu 14.04 and 16.04 vagrant
>>> I´ve installed geonode 2.6a1 and 2.6c1 from apt and from git!
>>> In every test case the geonode admin user is not automatically logged-in
>>> in geoserver. Even if I add GEONODE_BASE_URL (192.168.100.1)
>>> to web.xml as the documentation suggests nothing changes.
>>> The session cookie is valid for 192.168.100.1 / means geoserver
>>> should be able to read it.
>>> Has something changed with geoserver (2.9-SNAPSHOT) autologin in 2.6?
>>> cheers,
>>> Toni
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/caf71fba/attachment-0001.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/caf71fba/attachment-0001.sig>
More information about the geonode-users
