Hi Rasika,
in addition to Simone’s suggestions I recommend to detect the version automatically to avoid some kind of misalignment:
pip install gdal==$(gdal-config --version | awk -F'[.]' '{print $1"."$2}')
Il giorno 24/mag/2017, alle ore 15:46, Simone Dalmasso <simone.dalmasso at gmail.com> ha scritto:
> Indeed this is an issue with python gdal installation.
> if you have gdal 1.11 then you might have to do "pip install gdal==1.11.3"
> 2017-05-24 14:51 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> Thank you Simone.Now we solved the proxy issue but new problem arises with migration command.
> The django version for GeoNode 2.4.x is 1.6.11 which does not have migration support.
> So whenever I ran the coomand pyrhon manage.py migrate it is giving me eeror like
> Unknown command: 'migrate'
> Type 'manage.py help' for usage.
> Then we tried with python manage.py syndb
> that also not satisfied the problem.
> Then I tried with south app by seaching on net. but that was also giving me same error
> (both syncdb and south app giving error as follows)
> Not enabling BingMaps base layer as a BING_API_KEY is not defined in local_settings.py file.
> Traceback (most recent call last):
> File "manage.py", line 28, in <module>
> execute_from_command_line(sys.argv)
> File "/usr/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
> utility.execute()
> File "/usr/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/usr/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv
> self.execute(*args, **options.__dict__)
> File "/usr/lib/python2.7/site-packages/django/core/management/base.py", line 284, in execute
> self.validate()
> File "/usr/lib/python2.7/site-packages/django/core/management/base.py", line 310, in validate
> num_errors = get_validation_errors(s, app)
> File "/usr/lib/python2.7/site-packages/django/core/management/validation.py", line 34, in get_validation_errors
> for (app_name, error) in get_app_errors().items():
> File "/usr/lib/python2.7/site-packages/django/db/models/loading.py", line 196, in get_app_errors
> self._populate()
> File "/usr/lib/python2.7/site-packages/django/db/models/loading.py", line 78, in _populate
> self.load_app(app_name)
> File "/usr/lib/python2.7/site-packages/django/db/models/loading.py", line 99, in load_app
> models = import_module('%s.models' % app_name)
> File "/usr/lib/python2.7/site-packages/django/utils/importlib.py", line 40, in import_module
> __import__(name)
> File "/usr/lib/python2.7/site-packages/modeltranslation/models.py", line 84, in <module>
> handle_translation_registrations()
> File "/usr/lib/python2.7/site-packages/modeltranslation/models.py", line 80, in handle_translation_registrations
> autodiscover()
> File "/usr/lib/python2.7/site-packages/modeltranslation/models.py", line 31, in autodiscover
> import_module(module)
> __import__(name)
> File "/data/cms/geonode/geonode/base/translation.py", line 2, in <module>
> from geonode.base.models import (TopicCategory, SpatialRepresentationType, Region,
> File "/data/cms/geonode/geonode/base/models.py", line 28, in <module>
> from geonode.utils import bbox_to_wkt
> File "/data/cms/geonode/geonode/utils.py", line 28, in <module>
> from osgeo import ogr
> ImportError: No module named osgeo
> We have installed pip install gdal
> version of gdal=1.11.4
> Still the same problem arises.
> Please five any idea to solve this problem as soon as possible.
> Thank you
> On Wed, May 24, 2017 at 3:09 PM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi, seems that you have network issues. Not sure what can be, check that your server can correctly reach internet and if there are proxies, make sure your server is using them correctly.
> Best
> 2017-05-24 11:27 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> Thank you sir for your reply.
> After running the command that you mentioned in reply I am getting the following error:
> Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x2da6690>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/pip/
> Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x2da6810>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/pip/
> Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x2da6990>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/pip/
> Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x2da6b10>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/pip/
> Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x2da6c90>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/pip/
> Requirement already up-to-date: pip in /usr/lib/python2.7/site-packages
> I kept proxy settings in the terminal also. Kindly suggest me the way for installing it on my system.
> Thank you
> On Wed, May 24, 2017 at 12:34 PM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi, installation with pip is different from the installation with yum, try to update pip first with "pip install --upgrade pip" this may help you to find the correct pil.
> 2017-05-24 5:35 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> Hi,
> I am following the instructions metioned from below link to deploy Geonode 2.6.x in Rhel 7.2 64 bit machine.
> http://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/index.html
> when I am doing the step
> cd /home/geonode/geonode
> pip install -e .
> that is giving me error like pilliow version>=3.1.1 not satisfied.Also when I tried to update it with command
> yum update python-imaging
> it is showing uptodate.Nothing to do.And the version of python-pillow is 2.0.0-19 is already installed and latest one. And also serached on net for downloading latest rpm of python-pillow for rhel 7.2 but unable to find.
> Please suggest me to proceed further.
> Thank you
> On Mon, May 22, 2017 at 5:35 PM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi, you can follow this one, although we released the 2.6 and we have to update the version number in the docs.
> 2017-05-22 13:32 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> hello all,
> I want to install geonode on RedHat 7.0 ,64 bit OS.
> I got the following link when I searched for it.
> https://groups.google.com/forum/#!topic/geonode-users/jxgWTFQhrOA which is from year 2014 for the rhel 6.6.
> Please suggest whether the steps mentioned in above link will sufficient for deploying GeoNode latest version in Rhel 7.0.Please reply as soon as possible.
> Thank you
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/e3b18d49/attachment-0001.html>
