[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Tue Nov 7 07:06:21 PST 2017
Ciao Paolo.
Actually I'm getting an error:
$ python manage.py sync_geofence
('Unexpected error:', <type 'exceptions.AttributeError'>)
  File "manage.py", line 11, in <module>
    execute_from_command_line(sys.argv)
  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
    utility.execute()
  File
346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
    self.execute(*args, **cmd_options)
line 445, in execute
    output = self.handle(*args, **options)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/sync_geofence.py",
line 58, in handle
    print 'perm_spec is %s' % perm_spec
UnboundLocalError: local variable 'perm_spec' referenced before assignment
Thanks!
P.
On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Paolo
> while I am not sure why this is happening (it shouldn't), in GeoNode
> master there is now a sync_geofence command which will fix things:
> https://github.com/GeoNode/geonode/blob/master/
> geonode/geoserver/management/commands/sync_geofence.py
> It should work for 2.6.x as well, in case not let me know
> cheers
> p
> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
> paolo.pasquali at ithaca.polito.it> wrote:
>> Dear all,
>> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
>> every layer I upload does not appear in the GeoFence list.
>> I've tried to edit and save permissions, restart Apache, Tomcat, run
>> fixlayerpermission but with no result.
>> This is not happening in my local installation that reflects the affected
>> website.
>> Is there some action I can take except upgrading GeoServer?
>> Thanks.
>> Best,
>> Paolo
>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <alpacagis at gmail.com>
>> wrote:
>>> Dear list,
>>> It seems that the problem with the permission is solved with the
>>> upgrading of geoserver to 2.10 version
>>> Thanks Alessio for your help
>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>:
>>>> In that case you are correct. You need to double check that GeoFence
>>>> access rules have been correctly set on GeoServer for the layer you are
>>>> modifying.
>>>> If you cannot find them or the rules are not correctly updated, it is
>>>> possible that there is some communication issue between GeoNode and
>>>> GeoServer.
>>>> [image: Inline image 1]
>>>> Maybe try to do some tests and double check that the rules actually
>>>> change.
>>>> P.S.: do not use browser refresh on GeoFence Rules, but always click
>>>> here
>>>> [image: Inline image 2]
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> GeoServer Professional Services from the experts!
>>>> Visit http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> github <https://github.com/afabiani?tab=overview>
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility  for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <alpacagis at gmail.com>
>>>> wrote:
>>>>> Thanks  for your reply Alessio,
>>>>> about the layer preview question, I am logged in with the "SGI" user,
>>>>> that should be have the permission to see the layer.
>>>>> Moreover, the user that I'm using, is part of the "Staff" group, but I
>>>>> can't see the layer preview.
>>>>> Where I am wrong?
>>>>> [image: Immagine incorporata 1]
>>>>> Really thanks
>>>>> Federico
>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>> Hello,
>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>> groups.
>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>> Denominators
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>> alpacagis at gmail.com> wrote:
>>>>>>> Dear list,
>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>> 1- Layer permission issue:
>>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>>> or Geoserver?
>>>>>>> 2- Is it possible to fix a specific scale for the map view in the
>>>>>>> map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>> level that is closest to 1:250'000...)
>>>>>>> Thanks a lot
>>>>>>> Federico
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/b1f2f881/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/b1f2f881/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/b1f2f881/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/b1f2f881/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/b1f2f881/attachment-0007.png>
More information about the geonode-users mailing list
