[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Tue Nov 7 08:30:03 PST 2017
No stack trace. It seems it does nothing.
Thanks.
On Tue, Nov 7, 2017 at 5:21 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Paolo
> Strange, it should work. Can you remove the try/except block and send me
> again the stack trace?
> thanks
> p
> On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
> paolo.pasquali at ithaca.polito.it> wrote:
>> Ciao Paolo.
>> Actually I'm getting an error:
>> $ python manage.py sync_geofence
>> ('Unexpected error:', <type 'exceptions.AttributeError'>)
>> Traceback (most recent call last):
>>   File "manage.py", line 11, in <module>
>>     execute_from_command_line(sys.argv)
>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>>     utility.execute()
>> line 346, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>>     self.execute(*args, **cmd_options)
>> line 445, in execute
>>     output = self.handle(*args, **options)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/managem
>> ent/commands/sync_geofence.py", line 58, in handle
>>     print 'perm_spec is %s' % perm_spec
>> UnboundLocalError: local variable 'perm_spec' referenced before assignment
>> Thanks!
>> P.
>> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>> Hi Paolo
>>> while I am not sure why this is happening (it shouldn't), in GeoNode
>>> master there is now a sync_geofence command which will fix things:
>>> https://github.com/GeoNode/geonode/blob/master/geono
>>> de/geoserver/management/commands/sync_geofence.py
>>> It should work for 2.6.x as well, in case not let me know
>>> cheers
>>> p
>>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>>> Dear all,
>>>> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
>>>> every layer I upload does not appear in the GeoFence list.
>>>> I've tried to edit and save permissions, restart Apache, Tomcat, run
>>>> fixlayerpermission but with no result.
>>>> This is not happening in my local installation that reflects the
>>>> affected website.
>>>> Is there some action I can take except upgrading GeoServer?
>>>> Thanks.
>>>> Best,
>>>> Paolo
>>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <alpacagis at gmail.com
>>>> > wrote:
>>>>> Dear list,
>>>>> It seems that the problem with the permission is solved with the
>>>>> upgrading of geoserver to 2.10 version
>>>>> Thanks Alessio for your help
>>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>> In that case you are correct. You need to double check that GeoFence
>>>>>> access rules have been correctly set on GeoServer for the layer you are
>>>>>> modifying.
>>>>>> If you cannot find them or the rules are not correctly updated, it is
>>>>>> possible that there is some communication issue between GeoNode and
>>>>>> GeoServer.
>>>>>> [image: Inline image 1]
>>>>>> Maybe try to do some tests and double check that the rules actually
>>>>>> change.
>>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always click
>>>>>> here
>>>>>> [image: Inline image 2]
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> GeoServer Professional Services from the experts!
>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> github <https://github.com/afabiani?tab=overview>
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A
>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The sender
>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <
>>>>>> alpacagis at gmail.com> wrote:
>>>>>>> Thanks  for your reply Alessio,
>>>>>>> about the layer preview question, I am logged in with the "SGI"
>>>>>>> user, that should be have the permission to see the layer.
>>>>>>> Moreover, the user that I'm using, is part of the "Staff" group, but
>>>>>>> I can't see the layer preview.
>>>>>>> Where I am wrong?
>>>>>>> [image: Immagine incorporata 1]
>>>>>>> Really thanks
>>>>>>> Federico
>>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>>> Hello,
>>>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>>>> groups.
>>>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>>> Denominators
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>>>> Dear list,
>>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>>> 1- Layer permission issue:
>>>>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>>>>> or Geoserver?
>>>>>>>>> 2- Is it possible to fix a specific scale for the map view in the
>>>>>>>>> map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>>>> level that is closest to 1:250'000...)
>>>>>>>>> Thanks a lot
>>>>>>>>> Federico
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/952fca74/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/952fca74/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/952fca74/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/952fca74/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/952fca74/attachment-0007.png>
More information about the geonode-users mailing list
