[GeoNode-users] problem with sld
Ariel Neri ariel.neriw at gmail.com
Fri Nov 24 10:31:05 PST 2017
Hi, I had to adapt many complicated, hundred of clases simbology sld made
in qgis to be used in Geoserver some time ago.  I tried some programs with
no luck, so finally I changed a few things in the QGis sld file to make it
work in Geoserver.
Basically it´s just 3 steps, using the "search and replace" tool:
1-  i replaced the first line with one from an existing geoserver sld:
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns="
http://www.opengis.net/sld" xmlns:sld="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"
version="1.0.0">
2- Also copy the first lines raplacing the "****" with your own
<sld:NamedLayer>
                            <sld:Name>****** </sld:Name>
                             <sld:UserStyle>
                                             <sld:Name>*****</sld:Name>
                                             <sld:Title>******</sld:Title>
 <sld:Abstract>******</sld:Abstract>
                                             <sld:FeatureTypeStyle>
<sld:Name>name</sld:Name>
and do the same with the closings
                                               </sld:FeatureTypeStyle>
                               </sld:UserStyle>
                </sld:NamedLayer>
</sld:StyledLayerDescriptor>
3- Use the search and replace tool: replace    “<se:”  and   “</se:”
with “<sld:
(…)”  and  “</sld: (…)” respectivly. And replace  “SvgParameter” with
“CssParameter”
Sorry if i don´t use correct vocabulary, i´m not so much into coding,
neather into english language.
A co-worker made a script to do the steps before automatically with RStudio
and made it even simpler for me.
This was a good enough work-around for me and solved my problem. Probably
now there´s a better way (i hope so). I share anyway in case it helps you.
2017-11-24 14:43 GMT-03:00 Ivan Marchesini <ivan.marchesini at gmail.com>:
> Dear geonode users and developer
> I apologize if this is a well known problem but browsing on Internet
> (including the mailing list) I wasn't able to find a good solution
> I have recently installed geonode2.6 (ubuntu, ppa) for a project where
> multiple and not skilled users will be involved.
> I have tried to do a couple of things:
> 1) I uploaded a shapefile (separate files) together with a sld file
> exported from qgis. It happened to me that (i) the corresponding sld file
> created in geoserver is very different from the  original one (tipicaly the
> colors are lost)  and (ii) since the <Title> tag is not present geonode is
> only able to show me a style called "none"
> 2) I uploaded a shapefile (separate files) together with a sld file
> exported from udig. It happened to me that (ii) since the <Title> tag is
> not present geonode is only able to show me a style called "none"
> is there a way for creating a well formatted sld file for
> geoserver/geonode using some desktop GIS or some other tools with a GUI?
> It is very important to me since I can't ask the other colleagues to edit
> directly the xml files..  they will be too much scared by that!!
> thank you for your answers
> Ivan
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171124/857624f5/attachment-0001.html>
More information about the geonode-users mailing list
