[GeoNode-users] Missing columns after migrating data from Geonode 2.4 to 2.6
Israel López asralf at gmail.com
Wed Oct 18 17:06:47 PDT 2017
Hi everybody, just in this moment I found the same error trying to delete
some layers.
Looking around I found that the file migration is missing for the Upload
app, it only has the
24_initial.py, but this file includes the creation of the new fields, the
right way have to be two files,
the initial24.py and the 24_to_26.py as the other apps.
So as we run initial--fake, the tables are not created, the solution for me
was to delete the old
upload and upload_file tables (I don't know why are empty), delete the fake
migration in the
django_migrations table and run the migrate comand for upload, and thats
it, the tables were
created.
Hope this helps somebody. Greetings from Mexico.
2017-10-18 13:39 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Thanks all for the answers and feedbacks, we should investigate why
> "migrate" did not add those columns. It should be its job.
> Best
> 2017-10-18 20:10 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>> Thanks Annalisa, I ended up going that route too. I added those
>> columns and removed the not null constraint on last_login on
>> people_profile.
>> Eric
>> On Wed, Oct 18, 2017 at 2:49 AM, Annalisa Schiavon
>> <annalisa.schiavon at gmail.com> wrote:
>> > Dear Eric,
>> > on 3 July I found a similar issue: upload_upload table hasn't 4
>> attribute:
>> > mosaic_time_regex,
>> > mosaic_time_value, mosaic_elev_regex and mosaic_elev_value.
>> > I added those columns and solved my problem.
>> > Regards,
>> > Annalisa
>> > 2017-10-16 16:24 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>> >> Hi all,
>> >> We're trying to upgrade from GeoNode 2.4 to 2.6. I have a new VM with
>> >> Geonode 2.6 installed on Ubuntu 16.04 from the PPA. I dumped the
>> >> postgres data from our 2.4 server and created new DBs on the Geonode
>> >> 2.6 instance and updated settings.py to point to the geonode 2.4
>> >> geonode and geonode_data DBs.
>> >> Following the suggestion in this thread
>> >> (http://osgeo-org.1560.x6.nabble.com/Help-for-migrate-data-
>> from-2-4-to-2-6-td5323208.html),
>> >> I ran geonode migrate --fake-initial and everything appears to have
>> >> worked, however if I try to create a new account from the geonode
>> >> registration page, or delete an existing account from the admin panel
>> >> I get some errors.
>> >> Trying to create a new account results in the following error:
>> >> IntegrityError: null value in column "last_login" violates not-null
>> >> constraint
>> >>  Trying to delete an account results in the following error:
>> >> ProgrammingError: column upload_upload.mosaic_time_regex does not
>> exist
>> >> It looks like the migration didn't run correctly. If anyone has advice
>> >> on how fix/work a round this issue it would be greatly appreciated!
>> >> We'll be reloading the data anyway so our main concern is just
>> >> migrating the accounts and groups.
>> >> If it helps, here is the comparison of the geonode 2.4 and 2.6 schemas
>> >> for the upload_upload table. The mosaic* columns are missing from the
>> >> 2.4 database that was migrated:
>> >> geonode 2.4 database (after running migrate):
>> >> geonode24=# \d upload_upload
>> >>                                     Table "public.upload_upload"
>> >>    Column   |           Type           |
>>  Modifiers
>> >>  id         | integer                  | not null default
>> >> nextval('upload_upload_id_seq'::regclass)
>> >>  import_id  | bigint                   |
>> >>  user_id    | integer                  |
>> >>  state      | character varying(16)    | not null
>> >>  date       | timestamp with time zone | not null
>> >>  layer_id   | integer                  |
>> >>  upload_dir | character varying(100)   |
>> >>  name       | character varying(64)    |
>> >>  complete   | boolean                  | not null
>> >>  session    | text                     |
>> >>  metadata   | text                     |
>> >> Indexes:
>> >>     "upload_upload_pkey" PRIMARY KEY, btree (id)
>> >>     "upload_upload_layer_id" btree (layer_id)
>> >>     "upload_upload_user_id" btree (user_id)
>> >> Foreign-key constraints:
>> >>     "upload_upload_layer_id_fkey" FOREIGN KEY (layer_id) REFERENCES
>> >> layers_layer(resourcebase_ptr_id) DEFERRABLE INITIALLY DEFERRED
>> >>     "upload_upload_user_id_fkey" FOREIGN KEY (user_id) REFERENCES
>> >> people_profile(id) DEFERRABLE INITIALLY DEFERRED
>> >> Referenced by:
>> >>     TABLE "upload_uploadfile" CONSTRAINT
>> >> "upload_uploadfile_upload_id_fkey" FOREIGN KEY (upload_id) REFERENCES
>> >> upload_upload(id) DEFERRABLE INITIALLY DEFERRED
>> >> Geonode 2.6 database (from initial install):
>> >> geonode=# \d upload_upload
>> >>       Column       |           Type           |
>> >>  Modifiers
>> >>  session           | text                     |
>> >>  metadata          | text                     |
>> >>  mosaic_time_regex | character varying(128)   |
>> >>  mosaic_time_value | character varying(128)   |
>> >>  mosaic_elev_regex | character varying(128)   |
>> >>  mosaic_elev_value | character varying(128)   |
>> >>  user_id           | integer                  |
>> >> Indexes:
>> >>     "upload_upload_7a39a38c" btree (layer_id)
>> >>     "upload_upload_e8701ad4" btree (user_id)
>> >>     "u_layer_id_6346de911330a880_fk_layers_layer_resourcebase_ptr_id"
>> >> FOREIGN KEY (layer_id) REFERENCES layers_layer(resourcebase_ptr_id)
>> >>     "upload_upload_user_id_7fad116c8478bf31_fk_people_profile_id"
>> >> FOREIGN KEY (user_id) REFERENCES people_profile(id) DEFERRABLE
>> >> INITIALLY DEFERRED
>> >> Referenced by:
>> >> "upload_uploadfil_upload_id_21ef448d17dd4b6b_fk_upload_upload_id"
>> >> FOREIGN KEY (upload_id) REFERENCES upload_upload(id) DEFERRABLE
>> >> INITIALLY DEFERRED
>> >> Thanks!
>> >> Eric
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171018/2e70c05a/attachment.html>
More information about the geonode-users mailing list
