[GeoNode-users] Missing columns after migrating data from Geonode 2.4 to 2.6
Simone Dalmasso simone.dalmasso at gmail.com
Wed Oct 18 11:39:03 PDT 2017
Thanks all for the answers and feedbacks, we should investigate why
"migrate" did not add those columns. It should be its job.
Best
2017-10-18 20:10 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
> Thanks Annalisa, I ended up going that route too. I added those
> columns and removed the not null constraint on last_login on
> people_profile.
> Eric
> On Wed, Oct 18, 2017 at 2:49 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
> > Dear Eric,
> > on 3 July I found a similar issue: upload_upload table hasn't 4
> attribute:
> > mosaic_time_regex,
> > mosaic_time_value, mosaic_elev_regex and mosaic_elev_value.
> > I added those columns and solved my problem.
> > Regards,
> > Annalisa
> > 2017-10-16 16:24 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
> >> Hi all,
> >> We're trying to upgrade from GeoNode 2.4 to 2.6. I have a new VM with
> >> Geonode 2.6 installed on Ubuntu 16.04 from the PPA. I dumped the
> >> postgres data from our 2.4 server and created new DBs on the Geonode
> >> 2.6 instance and updated settings.py to point to the geonode 2.4
> >> geonode and geonode_data DBs.
> >> Following the suggestion in this thread
> >> (http://osgeo-org.1560.x6.nabble.com/Help-for-migrate-
> data-from-2-4-to-2-6-td5323208.html),
> >> I ran geonode migrate --fake-initial and everything appears to have
> >> worked, however if I try to create a new account from the geonode
> >> registration page, or delete an existing account from the admin panel
> >> I get some errors.
> >> Trying to create a new account results in the following error:
> >> IntegrityError: null value in column "last_login" violates not-null
> >> constraint
> >>  Trying to delete an account results in the following error:
> >> ProgrammingError: column upload_upload.mosaic_time_regex does not exist
> >> It looks like the migration didn't run correctly. If anyone has advice
> >> on how fix/work a round this issue it would be greatly appreciated!
> >> We'll be reloading the data anyway so our main concern is just
> >> migrating the accounts and groups.
> >> If it helps, here is the comparison of the geonode 2.4 and 2.6 schemas
> >> for the upload_upload table. The mosaic* columns are missing from the
> >> 2.4 database that was migrated:
> >> geonode 2.4 database (after running migrate):
> >> geonode24=# \d upload_upload
> >>                                     Table "public.upload_upload"
> >>    Column   |           Type           |
>  Modifiers
> >>  id         | integer                  | not null default
> >> nextval('upload_upload_id_seq'::regclass)
> >>  import_id  | bigint                   |
> >>  user_id    | integer                  |
> >>  state      | character varying(16)    | not null
> >>  date       | timestamp with time zone | not null
> >>  layer_id   | integer                  |
> >>  upload_dir | character varying(100)   |
> >>  name       | character varying(64)    |
> >>  complete   | boolean                  | not null
> >>  session    | text                     |
> >>  metadata   | text                     |
> >> Indexes:
> >>     "upload_upload_pkey" PRIMARY KEY, btree (id)
> >>     "upload_upload_layer_id" btree (layer_id)
> >>     "upload_upload_user_id" btree (user_id)
> >> Foreign-key constraints:
> >>     "upload_upload_layer_id_fkey" FOREIGN KEY (layer_id) REFERENCES
> >> layers_layer(resourcebase_ptr_id) DEFERRABLE INITIALLY DEFERRED
> >>     "upload_upload_user_id_fkey" FOREIGN KEY (user_id) REFERENCES
> >> people_profile(id) DEFERRABLE INITIALLY DEFERRED
> >> Referenced by:
> >>     TABLE "upload_uploadfile" CONSTRAINT
> >> "upload_uploadfile_upload_id_fkey" FOREIGN KEY (upload_id) REFERENCES
> >> upload_upload(id) DEFERRABLE INITIALLY DEFERRED
> >> Geonode 2.6 database (from initial install):
> >> geonode=# \d upload_upload
> >>       Column       |           Type           |
> >>  Modifiers
> >>  session           | text                     |
> >>  metadata          | text                     |
> >>  mosaic_time_regex | character varying(128)   |
> >>  mosaic_time_value | character varying(128)   |
> >>  mosaic_elev_regex | character varying(128)   |
> >>  mosaic_elev_value | character varying(128)   |
> >>  user_id           | integer                  |
> >> Indexes:
> >>     "upload_upload_7a39a38c" btree (layer_id)
> >>     "upload_upload_e8701ad4" btree (user_id)
> >>     "u_layer_id_6346de911330a880_fk_layers_layer_resourcebase_ptr_id"
> >> FOREIGN KEY (layer_id) REFERENCES layers_layer(resourcebase_ptr_id)
> >>     "upload_upload_user_id_7fad116c8478bf31_fk_people_profile_id"
> >> FOREIGN KEY (user_id) REFERENCES people_profile(id) DEFERRABLE
> >> INITIALLY DEFERRED
> >> Referenced by:
> >> "upload_uploadfil_upload_id_21ef448d17dd4b6b_fk_upload_upload_id"
> >> FOREIGN KEY (upload_id) REFERENCES upload_upload(id) DEFERRABLE
> >> INITIALLY DEFERRED
> >> Thanks!
> >> Eric
> >> _______________________________________________
> >> geonode-users mailing list
> >> geonode-users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171018/8cce8495/attachment-0001.html>
More information about the geonode-users mailing list
